Author Topic: Centipede low sound issue  (Read 3009 times)
hypergaming
  • Last login:May 04, 2022, 09:51:07 pm
« on: May 05, 2016, 08:15:09 pm »
Hi,
Does anyone know why my centipede cabinet game sound is low after replacing the board with a new one? The original board has some issues so I replaced it with another board I purchased.
The sounds was ok ( much louder ) with the original game board, after putting the new one in, the sound is very low. I tried adusting the volume control inside the cabinet but it doesn't seem to do anything but turn volume all the way down. If I turn all the way up nothing happens, stays at the same level.
Any help will be greatly appreciated.
  • Last login:Yesterday at 08:33:44 pm
Re: Centipede low sound issue
« Reply #1 on: May 05, 2016, 08:30:44 pm »
Check all your chips to make sure that they're seated properly. You might also want to change the Pokey chips between the two boards to see if that does anything.
hypergaming
« Reply #2 on: May 05, 2016, 08:52:01 pm »
could you give me a hint what the Pockey chip looks like and where in the board its located, offcorase am researching on google in case I find it sooner.
thanks man!
hypergaming
« Reply #3 on: May 05, 2016, 09:19:44 pm »
I research online and was able to identify the Pockey chip, the problem is, I have no clue how to tell if it is bad, or not put on correctly, it seems just like all the other chips, how do I test if its bad and need to get another one?
« Reply #4 on: May 05, 2016, 09:46:08 pm »
Before removing any chips, carefully note which way they are oriented. A notch on the chip will show you which way it goes.
Remove the Pokey from the old board,  and swap it on the new board.  See what happens.
