Author Topic: Make any joystick a 4-way, 8-way switchable joystick from the top of the panel!  (Read 18187 times)
megamoze
  • Last login:December 18, 2024, 04:05:59 pm
  • Loving my cabinet, built summer 2015
I've had mine installed for awhile.  They work as advertised and saved me a heap of trouble/money.  I think it works great and was well worth the investment for what I was looking for.
I can imagine that many here would object to the aesthetics of it.  They're not the prettiest, but not objectionable to me for my setup.
paigeoliver
  • Awesome face!
I am a purist and that looks fine. While different, it doesn't look "wrong", that could totally be a joystick on a factory built machine.
KenToad
  • Last login:March 16, 2026, 05:48:29 pm
  • Flap Flap Flap
It looks fine to me, definitely not bad. I'm considering getting a pair of them myself. What I'm worried about is how they feel. Do you notice the screw heads rubbing against your palm or anything else that might be unusual?
Thanks for posting the pic and any additional information.
pixel
  • Last login:December 24, 2019, 05:33:55 pm
 Its an interesting design... but I can not see that lasting a  "Lifetime".   Those thin plastic fins are going to wear down pretty fast from any decent amount of play.   If you put this in a busy location,  in a MsPacman...  It probably would not last 3 months.
 Also, due to the sharp nature of contact points, and low surface area (thickness of the walls),  ... its going to dig into any bats plastic shaft as well.
 Now, maybe if you are one of these people whom play with no force or frenzy at all... you may get longer lasting results.   But typical players will see wear.
 Being a former arcade mgr..  I used to have Happ's 8-way joystick spacers wear down like crazy.   Maybe 6 months...  then you had to flip them over.  You would look down into the control panel,  and see fine white dust piles... from where the spacer grindings landed.
 I suppose if its cheap enough, people wont mind replacing it, regardless.
 Even the Old Wico 4ways,  which used a fairly thick plastic diamond shaped hole.. reinforced with an internal metal part..  would wear down eventually.  The Old Bally 4 ways,  were probably the best... in that they had a thick solid metal top diamond,  and a replaceable bottom mounted diamond made of plastic.   The rubber grommet helped greatly to reduce impact and thus, reduce outer-edge wear.
megamoze
It's not uncomfortable but you definitely feel that it's there.  I don't notice the screws, which are pretty small, but I do notice the edge of the plate itself.  It's a fairly hard plastic with a texture on it and the corners aren't rounded at all.
Again, not uncomfortable and it doesn't bother me, but it's not an invisible experience.
Slippyblade
Just run a file around the edge to break the corner.  Makes all the difference in the world.
