Author Topic: T-Molding - Securing  (Read 1387 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: April 29, 2016, 09:34:08 am »
Hi folks:
I have a CAB that has the grooves for the T-Mold a bit too wide, so the molding doesn't fit in - this is just at the bottom corner of the cabinet on all 4 corners.
Anyone with suggestions on how to secure in place?   I have a concern on one corner as the T-Molding is cut short and is at the tip of the corner were it curves, so it springs up a lot, and will need to secure that part down the most.
I thought of using Lepage PL Premium Construction adhesive to clue it down.   Thoughts?
behrmr
Re: T-Molding - Securing
« Reply #1 on: April 29, 2016, 09:39:39 am »
Fill the groove with hot glue and press t-molding in and hold firmly until hot glue cools.  You can secure the tail end under the cabinet with a staple or two since no-one will see that.   The nice thing about hot glue is that it is pretty easy to remove if you need to.  You can also try to fold a piece of electrician's tape or duct tape over the t-molding barb to make it grab in the slot.   Or fill the groove with bondo and t a new slot.  Good luck.
« Reply #2 on: April 29, 2016, 10:13:06 am »
just don't nail it and you're good...
  • Last login:Yesterday at 11:50:38 am
Richardgregory
« Reply #4 on: April 29, 2016, 11:20:23 am »
Hot glue gun it is - thanks all! :)
« Reply #5 on: April 29, 2016, 03:09:52 pm »
i use PL
