Author Topic: What PC spec is enough to run mala with videos without slowdowns?  (Read 5805 times)
TopJimmyCooks
Going down the rabbit hole here- I just started using a craftymech SLG running windows at 1024x768 and forcing mame to run at 640x480.  To get consistent scan lines and placement of the picture on the display, I really need to run windows and everything at 640x480.  Which means I need to redo my Mala layout in a new low res friendly version.
If I redo my layout, I really want to run game videos.  I know on the cheap pc I have (XP, celeron 2.4ghz, 512mb ram) it makes the gamelist too slow to scroll with videos on.  What is a minimum spec pc to load videos fast?  i know there is a delay capability in mala so the vid doesn't start until you've rested on the game for a second.
ramos8414
  • Last login:January 09, 2019, 08:27:24 pm
Re: What PC spec is enough to run mala with videos without slowdowns?
« Reply #1 on: May 14, 2016, 12:53:30 am »
I have XP, 2.66Ghz pentium 4, with 1Gig of Ram and it still struggles to with videos. Get a core 2 duo to be safe. They arent too expensive these days and they can run most games on mame. It should handle videos, with no slowdown.
big10p
  • Mmmm, arcade classics!
« Reply #2 on: May 15, 2016, 07:48:07 am »
This is probably more of an issue with how quickly MaLa can load the videos. I use SSDs in my rigs and they make a world of difference in loading times - most noticeably in boot-to-menu speed. I also recommend using a short delay before playing vids. Just have a snapshot show for a second before the video plays.
Also, you have a tiny amount of RAM. Get some more! :) 2 gig minimum, I would say.
« Last Edit: May 15, 2016, 07:52:41 am by big10p »
« Reply #3 on: May 20, 2016, 11:46:26 am »
What most people end up doing is having the video window displayed over top the gameplay pic in their Mala layout with the video start on a delay.
(video is always on top anyway).
As you scroll through the list, the pics are displayed which is fast.
Then if you stop on a game for a half second or so, the video plays.
It keeps the scrolling at a good pace.
