Author Topic: GM.169 issue  (Read 2717 times)
Sledge
  • Last login:August 02, 2025, 01:37:53 am
GM.169 issue
« on: April 17, 2016, 09:19:57 am »
Hi guys,
So i haven't updated to the latest yet, but not too far behind.
I HAVE updated to CRT drivers 2.0
I went to play some games today, and noticed that slapfight seems to have audio issues (sounds sort of play twice/echo)
Also i noticed that Slapfight doesn't run at the correct res or speed. Log attached..
Snow Bros doesn't get sync, however Snow Bros 2 does.. (didn't get a log for this yet)
Seems to be the same whether i use d3d or d3d9ex
And i forgot to grab my mame.ini too
using the ms9 preset for 15k only.
Any ideas?
« Last Edit: April 17, 2016, 09:21:37 am by Sledge »
Calamity
  • Moderator
  • Last login:Yesterday at 03:16:11 pm
  • Quote me with care
Re: GM.169 issue
« Reply #1 on: April 18, 2016, 07:05:47 am »
By any chance, did you enable frame delay in mame.ini instead of doing it per game?
Steps to create a log:
Sledge
Re: GM.169 issue
« Reply #2 on: April 18, 2016, 05:59:55 pm »
I don't think so, but i will check on the weekend
I'm pretty sure i haven't enabled framedelay at all....
Sledge
Re: GM.169 issue
« Reply #3 on: April 22, 2016, 07:31:57 pm »
Nope all good as far as i can see...
Sledge
Re: GM.169 issue
« Reply #4 on: April 24, 2016, 09:46:36 pm »
tried creating a new mame.ini just in case i'd done something wrong and it still does the same thing
Only thing i changed in the mame.ini was my monitor profile, and rom location and enabled MT
But Snow Bro's gets sync now, so all good there, but Slap fight is still running wrong...
Might have to enable triplebuffering? But isn't that enabled automatically when you use MT ?
I should just get my vertical cab running properly as it runs correctly in vertical mode..
« Last Edit: April 24, 2016, 10:44:47 pm by Sledge »
sean_sk
  • Last login:August 06, 2019, 10:27:48 am
  • If quizzes are quizzical, then what are tests?
Re: GM.169 issue
« Reply #5 on: April 24, 2016, 11:00:58 pm »
Yes, you need to enable triple buffering if running a 288 line vertical game on a standard 15kHz horizontal monitor.
« Last Edit: April 24, 2016, 11:02:44 pm by sean_skroht »
Sledge
Re: GM.169 issue
« Reply #6 on: April 24, 2016, 11:15:24 pm »
Oh shut up you
