Author Topic: CRT Emudriver 2.0 - 31k Modelines  (Read 4414 times)
Thamiel
  • Last login:June 03, 2025, 05:28:11 am
« on: March 30, 2016, 07:58:45 am »
Hey guys, just picked up a 7850 and have been giving the new drivers a go. Install went very smoothly, just want to make sure my modelines look right. Only have 3 installed, log attached.
I used my old 31k SuperRes list (from cools example settings).
EDIT: Nah, i've definitely done something wrong. MK2 is displaying at 2560x960i
« Last Edit: March 30, 2016, 09:49:30 am by Thamiel »
Thamiel
Re: CRT Emudriver 2.0 - 31k Modelines
« Reply #1 on: March 31, 2016, 06:57:28 pm »
Any of you guys running 2.0 have any ideas? Actually I should probably post some more info, will do when I'm home.
Sent from my C6603 using Tapatalk
  • Last login:Yesterday at 08:05:28 am
« Reply #2 on: April 01, 2016, 03:53:57 am »
If you're using the arcade_31 preset, try increasing the Hfreq max value a little bit. You need a 2560x512 mode in there for mk.
Thamiel
« Reply #3 on: April 06, 2016, 06:45:31 am »
Gave that a go but i'm still missing something I think, some modelines arn't getting installed by vmm. Attached a log and the modelines i'm getting.
« Last Edit: April 06, 2016, 07:05:10 am by Thamiel »
« Reply #4 on: April 06, 2016, 07:31:39 am »
Please post your preset (crt_range).
Thamiel
« Reply #5 on: April 07, 2016, 08:55:48 am »
No worries.
monitor "arcade_31", "Arcade 31.5 kHz - high resolution", "4:3"
        crt_range0 31400-31500, 49.50-65.00, 0.940, 3.770, 1.890, 0.349, 0.064, 1.017, 0, 0, 384, 480, 768, 960
Thamiel
« Reply #6 on: April 12, 2016, 07:16:27 pm »
Having more success using a different preset, though things still arn't 100% right. rsgun is defintely picking a wrong resolution and ending up squished in the middle. I've attached the new preset, vmm install log and the modelines installed. When you have a sec i'd apprecite your thoughts.
Incidentally, I found the signal chart for my monitor (Nanao MS2934). Just not sure how to go about transferring that to a monitor preset.
« Reply #7 on: April 13, 2016, 01:57:29 pm »
Three files attached but not the one we need: groovymame log.
Thamiel
« Reply #8 on: April 13, 2016, 04:50:01 pm »
Apologies, log is attached. It's the 720x480p mode being selected that's squashed and incorrect.
« Reply #9 on: April 13, 2016, 04:53:50 pm »
Set "resolution 2560x0" in mame.ini, since you're using super resolutions. That will fix it.
Thamiel
« Reply #10 on: April 14, 2016, 03:56:13 am »
Thanks mate, that got it. Forgot to put that back in after I tried again with a new mame.ini
