Author Topic: How to fit the E-clip washer on the bottom of a joystick  (Read 2468 times)
Topogram
  • Last login:July 07, 2016, 05:34:47 am
« on: March 30, 2016, 04:01:48 am »
I'm currently building my first control panel. I have the Happ Super joystick. I understand that the shaft of the stick goes in the hole in the bottom box and then you need to place the metal E-clip over the end of the shaft to keep it in place. What I can't work out is how to do this! I seem able to push the actuator up a bit so I can just get the E-clip in place but I'm worried the micro switches will get damaged. Do they need to be removed before you put the washer on?
Sorry for what is probably a stupid question.
  • Last login:Today at 04:59:53 am
Re: How to fit the E-clip washer on the bottom of a joystick
« Reply #1 on: March 30, 2016, 05:22:18 am »
Welcome aboard, Topogram.   ;D
No need to remove the microswitches when installing the E-clip.
Hold the handle in place while pushing on the actuator to install the clip as shown from 17:03-17:28 and 18:26-18:36 in this video.
http://youtu.be/fr6GcmL2FVc?t=1023
