Author Topic: Ultrastik issue after migration to windows 7  (Read 1280 times)
shiloh
  • Last login:May 10, 2016, 02:58:07 pm
« on: March 25, 2016, 04:57:51 pm »
hello everyone!
I am in the process of upgrading the computer in my 7 years old cabinet. The old PC was running XP and the new PC is running Windows 7. Both are currently installed in my cabinet for testing purpose, so I can switch between the old one and the new PC. On my control panel I have 2 Ultrastik 360.
The issue I am facing is the following:
When I use my new PC, my UltraStik #1 is not responding after windows has started. To get it to work, I have to start the UltraMap tool, program the stick to any other map than analog. This will get the stick alive, then I can reprogram it to "analog" (my default configuration) and it will work fine.
My ultrastick #2 doesn't have the same behavior and works perfectly all the time.
When I switch back my control panel to my old PC (running XP) my stick #1 will work perfectly and do not have the issue described above. Switch my CP again to my windows 7 PC and the issue is back. I am doing a full shutdown and power off of both PC to switch my Stick from one PC to the other.
One thing to note: My stick #1 is running firmware 2.5 (the board was replaced a couple of years ago) and my stick #2 is still running firmware 2.3. I tried to download the firmware 2.5 from Ultimarc to bring both stick to 2.5 but the download link is broken. Also, I have the issue with only running stick #1 (stick #2 disconnected).
Anyone have any idea?
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: Ultrastik issue after migration to windows 7
« Reply #1 on: March 26, 2016, 05:11:03 am »
Hi, if you can contact me directly we can resolve this: andy@ultimarc.com
Andy
dfwdennis
  • Last login:April 22, 2016, 06:12:23 pm
« Reply #2 on: March 26, 2016, 11:09:43 am »
I have the same issue.  I struggled with it for a while, and then just ended up creating a batch file that I run when my PC boots.  The batch file sets the joystick to a non-analog profile and then back to analog.  I no longer notice this odd behavior.
shiloh
« Reply #3 on: March 27, 2016, 09:43:00 am »
dfwdennis: did both sticks were having the issue or just one like me?
dfwdennis
« Reply #4 on: March 27, 2016, 09:49:22 am »
I only have one.
  • Last login:November 13, 2025, 08:40:37 pm
« Reply #5 on: March 27, 2016, 11:04:22 am »
Slightly off topic - I hope you get your Ultrastik issue squared away.
I ran into an issue when I migrated to Windows 7 and found some new shortcuts in Windows 7 compared to XP. Specifically, CNTL+ALT+Arrow keys. I have to remap my ipac.
