Author Topic: ATARI TETRIS - Identifying missing component on PCB  (Read 2590 times)
powerball
  • Last login:May 15, 2016, 04:02:35 pm
« on: March 25, 2016, 09:07:35 am »
Need help to identify missing transistor on the PCB as marked in picture.
Anyone got a schematic or a board to verify which type of transistor used ?
ed12
Re: ATARI TETRIS - Identifying missing component on PCB
« Reply #1 on: March 25, 2016, 01:48:49 pm »
er u mean by-pass filter
.01/50
ed
powerball
« Reply #2 on: March 25, 2016, 05:41:51 pm »
No, there's a connection point With 3 solder pads. I'm almost sure that a transistor should be there.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: March 31, 2016, 06:06:16 pm »
IIRC the consensus is that there is no schematic out there for Atari Tetris. The closest I have seen is a partial of R20,30,40 in the Troubleshooting section of the manual.
Pictures of the board appear to show a transistor there. Repair logs talk about a transistor at B10, but nobody seems to mention the specifics. If I had to guess completely blind, I would guess 2N3904.
The good news is you don't have to guess (and I can't believe I am going to plug his YouTube channel) that BYOACer ChanceKC's pal Josh did a video on repairing the audio section of an Atari Tetris board ... so he has one and can check for you (hit him up by PM or over on KLOV).
« Last Edit: March 31, 2016, 06:22:35 pm by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
CheffoJeffo
« Reply #4 on: March 31, 2016, 06:20:11 pm »
2N5304?
Working: Not Enough
Projects: Too Many
Progress: None
