Author Topic: Looking for an adapter for Ultimarc U360  (Read 1384 times)
MydknyteStyrm
  • Last login:March 20, 2024, 12:19:41 pm
  • Makeup FX Gamer
« on: March 24, 2016, 07:14:55 am »
Hi everyone,
I am looking to fit crystal clear bat tops to my existing U360 bat top shaft. The shaft has a 10mm thread, but the crystal clear bat top I got is 6mm. I've seen adapters to fit 10mm onto a 6mm shaft, but I need it in reverse. Basically a female threaded 10mm with a male 6mm thread. If this isnt a viable option, does anyone know if its possible to switch the bat top shaft of the U360 with a ball-top shaft, which I believe is 6mm threaded? I dont want to replace the entire stick, and it would need to fit onto the existing U360 magnet. Thanks!
