Author Topic: cga to vga, will this work? updated  (Read 5139 times)
abispac
  • Last login:January 31, 2026, 11:05:56 am
« on: March 19, 2016, 10:11:22 am »
Since im building a pacman cab but i wont use an old crt monitor, i thought of using a converter to use anlcd monitor instead, so i need advice to know if this would work.
http://www.ebay.com/itm/172013859498?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
thanks for any help.
« Last Edit: March 21, 2016, 12:47:18 am by abispac »
  • Last login:Yesterday at 06:20:48 pm
Re: cga to vga, will this work?
« Reply #1 on: March 19, 2016, 11:03:33 am »
Aw, man, if you're going to go through the trouble of using an original board, you should try to use an original monitor as well.
« Reply #2 on: March 19, 2016, 11:06:39 am »
Having said that, I'm not sure if those will work. I could swear those have been posted here before, and somebody said that they didn't work as easily as we thought they did.
dmckean
« Reply #3 on: March 19, 2016, 12:44:16 pm »
I think these are supposed to work OK, but add about a frame of lag.
http://www.amazon.com/KingMas-GBS-8220-Arcade-Video-Converter/dp/B0051SLJAG
There really isn't a good product out there for this though. I remember that CraftyMech was working on a CGA to VGA converter with built in scanline generation, but I don't think anything ever came of it.
« Reply #4 on: March 19, 2016, 06:36:40 pm »
I tried one of those with a Centipede pcb. The lag was horrible.
« Reply #5 on: March 19, 2016, 06:41:33 pm »
@abispac, did you see this at the bottom of the listing..?
*Please note that this board does not convert frequencies.  Regular PC LCD monitors won't work.  Please use open frame LCD screen designed for gaming.
dmckean
« Reply #6 on: March 19, 2016, 06:50:37 pm »
If that's the case, I don't think he really has any good options.
Probably have to use a PC and MAME.
« Reply #7 on: March 19, 2016, 06:51:34 pm »
Yep. That's why I recommended a CRT.
abispac
dmckean
Re: cga to vga, will this work? updated
« Reply #9 on: March 21, 2016, 01:04:30 am »
I think you'd be taking your chances. Most of these types of boards are reported to not work very well with older, non-JAMMA stuff.
dmckean
« Reply #10 on: March 21, 2016, 01:06:56 am »
You should just buy one though, it's only $22. If it doesn't work, sell it here for $10.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #11 on: March 21, 2016, 03:45:30 pm »
Yeah, the choice of original board and VGA LCD is a bit baffling to me. Better off using MAME.
Working: Not Enough
Projects: Too Many
Progress: None
dmckean
« Reply #12 on: March 21, 2016, 05:03:54 pm »
It's not like he's losing anything using MAME, the emulator for Pacman has been perfect for a long time.
« Reply #13 on: March 21, 2016, 06:40:50 pm »
Right. That's why wanting to use an original board with an LCD is a bit  uninspired.
CheffoJeffo
« Reply #14 on: March 21, 2016, 08:53:25 pm »
If it were going on route, I would be all for original board and LCD (but a real arcade LCD that supports CGA), but an original board with a VGA LCD is completely counter-intuitive to me. Did he mention if he is going original power supply too? Doesn't it use crazy AC voltages?
Way too much pain to half-ass the part of the game that you look at.
Working: Not Enough
Projects: Too Many
Progress: None
abispac
« Reply #15 on: March 22, 2016, 12:52:13 pm »
all i wanted it to have was a bartop with anoriginal board, but it looks like its too much so ill keep it emulation style, and i will buy a board to build  or restore a pacman cab. thanks for everyone feedback.
« Reply #16 on: March 22, 2016, 01:35:13 pm »
I feel weird for suggesting it, but just get a 60 in 1 and an LCD
