Author Topic: Wiring question terminal blocks in control panel  (Read 1301 times)
Vincefaro
  • Last login:July 17, 2025, 11:40:56 am
« on: March 15, 2016, 01:35:33 pm »
Hi, I am trying to plan my control panel for my project and I have a question regarding the Terminal blocks . If say I have a 10 position and I bring power +5v in on one side and I have the LED button wires on the other will the power distribute to all of the buttons or do I need to wire each position on the power side to the buttons side?
  • Last login:Today at 04:43:22 pm
Re: Wiring question terminal blocks in control panel
« Reply #1 on: March 15, 2016, 01:59:42 pm »
Each screw only connects with the screw on the opposite side of the strip.
To use the terminal strip for voltage distribution, you can use wire jumpers or a jumper strip like this.
https://www.radioshack.com/products/radioshack-8-position-jumper?variant=5717449157
Vincefaro
« Reply #2 on: March 15, 2016, 02:26:42 pm »
I thought so , Like Chance did here?  Thank you
« Reply #3 on: March 15, 2016, 02:35:51 pm »
Yes.  That would be the wire jumper approach.   ;D
