Author Topic: Joystick,Keyboard,I-Pac 2 questions  (Read 1870 times)
superman2k2
  • Last login:April 17, 2017, 02:37:47 pm
« on: March 13, 2016, 02:40:42 pm »
Hello I purchased an Arcade Cab a week ago and it is connected with what looks like an old I-pac pcb and connect with AT keyboard (pic below). I have it hooked up and it works fine sometime but when playing 2 player games sometime only one person button presses register at a time. My question is if I buy an I-Pac2 would it fix this problem since its usb instead of AT? Also would like to connect the control panel as default Xbox 360 controllers  and NOT have it emulate a keyboard would an I-Pac 2 allow me to do that and if not how would I do that? Thanks for all advise.
jeremymtc
  • Last login:February 04, 2026, 02:06:27 pm
Re: Joystick,Keyboard,I-Pac 2 questions
« Reply #1 on: March 14, 2016, 11:24:20 pm »
IPACs are keyboard encoders, and while there may be software solutions that might allow you to convert keystrokes to joystick signals, you'd be better off using a gamepad type encoder for what you're trying to do. These are a few popular options:
Ultimarc's Uhid http://www.u-hid.com/home/overview_board.php
GGG GP-Wiz http://groovygamegear.com/webstore/index.php?main_page=index&cPath=76_81
Xin Mo http://www.paradisearcadeshop.com/xin-mo/24-arcade-controller-to-usb.html
There are others with more or fewer features depending on what you need, like the Kade or the Zero Delay. You can gut out a cheapie gamepad and just use the PCB. Lots of options.
superman2k2
« Reply #2 on: March 14, 2016, 11:39:03 pm »
Thank You
