Author Topic: rowe cd100a wire harness problem  (Read 2240 times)
du24pont24
  • Last login:April 30, 2017, 12:49:56 pm
  • I have a CD100a Rowe Juke box.
« on: February 27, 2016, 10:42:36 pm »
Can anyone tell me were I can find the metal end that clips into the harness.  It should be on the end of the loose wire!   Or do I havewe to buy a whole new harness and splice the 3 wires together?  Also what is the wire I would need to buy, the wire is very short to plug into the harness.
Thanks for any info!
Derek
South Bend, IN, USA
lilshawn
  • Last login:Yesterday at 11:14:57 am
Re: rowe cd100a wire harness problem
« Reply #1 on: March 03, 2016, 02:27:41 pm »
They are all standard connectors.  You should be able to buy one and crimp on a replacement.
If you are brave you can plug the pin connector out and reattach the wire and then reinsert it.
du24pont24
« Reply #2 on: March 13, 2016, 10:13:33 pm »
Where would I purchase the connector???  radio shack?   lowes??/ menards???
Is a web site I could buy from???   Thanks!!!
Derek
Derek
South Bend, IN, USA
lilshawn
« Reply #3 on: March 14, 2016, 02:34:54 am »
I want to say JST XH series connector.  I'd have to dig up an manual to find out for sure.
A dataset for them can be found here...
http://datasheet.octopart.com/XHP-4-JST-datasheet-8325564.pdf
Takes some measurements and compare them to see.
Ebay or mouser or any large electronics place would have them.
