Author Topic: Base of cabinet - 2x4 or MDF enough?  (Read 1117 times)
PC509
  • Last login:March 03, 2016, 01:30:47 pm
« on: February 27, 2016, 07:37:56 pm »
The last cabinet I built was in the early 90's in wood shop. It had a lot of middle support to hold a heavy CRT. This time, I'm doing less support in the middle area and only going with a LCD (and no console shelf).
But, since I'm using less mid support, I'm wondering if I should use a 2x4 reinforced base... I've seen some with them, and some without. But, if I move it around a bit, I want it to be sturdy enough to not fall apart. I'm guessing not, but I want to be really sure on it as I'm getting to the point to get everything screwed together. I have all the parts (sans plexiglass and marquee), just time to put things together and play some games. :)
Thanks! I've found a ton of ideas so far, and it's finally coming to fruition.
paigeoliver
  • Awesome face!
Re: Base of cabinet - 2x4 or MDF enough?
« Reply #1 on: February 28, 2016, 08:57:17 pm »
I like a 2x4 base, it both makes the cabinets sturdy and it makes them easy to repair if they get damaged.
jaywv1981
  • Last login:May 17, 2022, 10:14:07 am
« Reply #2 on: February 29, 2016, 10:32:57 am »
I built my base out of 2x4s also.  I don't feel it would have been sturdy enough without it.
PC509
« Reply #3 on: March 03, 2016, 12:46:22 pm »
Awesome. Thanks!
I'm finishing my control panel this weekend (vinyl comes in from Gameongrafx today!). Hopefully the rest of the cab next week. 2x4's it is. I already have the wood, just didn't want to add more wood unnecessarily!
