Author Topic: Need some old school Optipac help - serial mouse  (Read 2162 times)
  • Last login:Yesterday at 04:50:19 pm
« on: February 24, 2016, 06:17:35 pm »
This is a pic of my Optipac. I'm curious if I'm doing anything wrong. It's a HAPP trackball and the green\yellow cable is the +5v and the blue wire is the ground. I'm using a straight through serial cable. I'm not 100% sure of the jumpers. I'm using Windows 7. The Serial ports are enabled in the BIOS.
I've read some other posts and people are talking about a serial to USB cable.
Anyone see anything obvious?
BuZz880
  • Last login:November 16, 2023, 02:16:43 pm
Re: Need some old school Optipac help - serial mouse
« Reply #1 on: February 25, 2016, 01:17:13 am »
So what's going on?  Not working? Looks about right to me but I do have the serial to USB cable from ultimarc. You might try going into device manager and try to see if the device shows up. Also check ultimarc maybe there's a driver you need. Not sure. Andy at ultimarc will respond if you ask him a question.
Sent from my Nexus 6P using Tapatalk
« Reply #2 on: February 25, 2016, 02:11:20 am »
It's not working. No X or Y axis and it's not showing up as a mouse device.
I'm pulling my 5V from a switching PSU - not sure if that matters.
jeremymtc
  • Last login:Yesterday at 08:35:41 pm
« Reply #3 on: February 25, 2016, 03:45:14 am »
Could be a driver problem. I presume that the serial port is on the motherboard... Have you tried updating the chipset drivers from the mobo manufacturer?
« Reply #4 on: February 25, 2016, 09:27:09 am »
What I should do is plug in a different serial device, but I'm practically positive it would work. It's one of the basic machines that TKWarrior is selling which is pre-setup. I'm very familiar with driver installation, and device manager shows no errors.
« Reply #5 on: March 06, 2016, 01:41:48 pm »
For anyone tracking this, I ditched the serial mouse and used a new USB encoder and getting much better response and no backspin issues. I'm sure they could have been overcome using the appropriate cable, settings, etc, but a new encoder was less than $15. I did have to do a little work: http://forum.arcadecontrols.com/index.php?topic=149845.msg1565206#msg1565206
Overall, totally worth it!
