Author Topic: What settings for using GM on a vertical monitor?  (Read 4474 times)
big10p
  • Mmmm, arcade classics!
« on: February 18, 2016, 07:49:43 am »
Hi
I've just installed CRT emudriver v2 and GM on my vertical cab, and have set the desktop to portrait. Now I want to create all the modes I'm going to need, but unsure of the best way to go about this for a vert monitor. I only want to play vert games using GM, on this cab.
What's the best way to create all the modes I'll need? Do I still need super resolutions?
Any tips on settings I need make in VMMaker and MAME.ini would be appreciated.
Thanks.
  • Last login:Today at 01:18:47 pm
Re: What settings for using GM on a vertical monitor?
« Reply #1 on: February 18, 2016, 08:07:31 am »
It's pretty straight forward.
In VMMaker, pick the right orientation, either "rotating to right" or "rotating to the left" (yes, even if it's not a rotating monitor).
If your desktop is set to portrait, then check the box "Desktop rotates too".
Make sure "Export settings to GroovyMAME" is checked, with the correct GM path.
Just generate and install the modes as usual, super resolutions are fine.
I'd say VMMaker already cares of this, but make sure that it sets aspect 3:4 in mame.ini. (3:4 because that's the rotated aspect).
big10p
« Reply #2 on: February 18, 2016, 09:13:59 am »
Thanks, I did all that but something's not right. e.g. I have created a 288x240 mode, but when I run Pac-Man, switchres chooses 488x240 mode instead, and the game is displayed too tall & narrow (squashed in on the sides), with bad scaling. This still happens if I force 288x240 mode.
Any ideas?
« Reply #3 on: February 18, 2016, 10:19:01 am »
big10p
« Reply #4 on: February 18, 2016, 10:36:55 am »
OK, here's a log and the mame.ini.  :)
« Reply #5 on: February 18, 2016, 11:42:47 am »
That's odd. Are you using the final 0.015l version? It's working fine here, even with your mame.ini.
Check my log:
SwitchRes: [ 288]x[ 240]_(60=59.965519Hz)
   rng(0):  288 x 240_60.606060p 15.757576 [integ] scale(1, 1, 1) diff(0.00, 0.77, 0.0000) ratio(1.000, 1.071)
vs yours:
   rng(0):  288 x 240_60.606060p 15.757576 [fract] scale(1, 1, 1) diff(36.25, 0.77, 0.0000) ratio(1.000, 1.071)
big10p
« Reply #6 on: February 18, 2016, 12:25:08 pm »
I'm using latest GM - v170 - so yes, I'm using switchres 0.015l.
I'm getting the tall/narrow display with all games. Deleted all mame .cfg and .ini files to make sure.
« Last Edit: February 18, 2016, 12:28:38 pm by big10p »
brad808
« Reply #7 on: February 18, 2016, 12:31:14 pm »
I had the same issue. What I did was start from scratch, set everything up as if going horizontal with super resolutions in vmmaker, leave the desktop horizontal. After all that is done and GM is working, go to desktop and rotate, then the final step was in groovymame ini set orientation to vertical and and ratio 3:4. Trying to set up vmmaker with vertical desktop was nothing but headache for hours.
« Last Edit: February 18, 2016, 12:33:51 pm by brad808 »
big10p
« Reply #8 on: February 18, 2016, 12:38:11 pm »
Thanks for the tip - I'll do that. Found that changing my desktop back to landscape also gets switchres to select the right mode (and display the game un-squashed), if I select rotate from the MAME menu.
« Reply #9 on: February 18, 2016, 02:38:22 pm »
I don't understand anything. Here it just worked without an issue.
big10p
« Reply #10 on: February 18, 2016, 07:11:55 pm »
Beats me. No matter what I try, switchres picks the wrong mode and displays the game too narrow/tall, if I have the desktop set to portrait.
I'm using the H9110 preset with an HD 5450, if that makes any difference?
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #11 on: February 18, 2016, 10:11:43 pm »
I leave the desktop as is, but then use irotate to rotate the picture. Switchres picks correct resolution for me..
BUT I haven't updated that can to latest versions yet..
« Reply #12 on: February 19, 2016, 04:18:44 am »
Hi big10p,
Please zip your complete MAME folder and upload it somewhere so I can grab it (I mean without the roms of course).
big10p
« Reply #13 on: February 19, 2016, 05:56:19 am »
Hi big10p,
OK, I'll do that today.
big10p
« Reply #14 on: February 19, 2016, 07:24:29 am »
Ah! Was just about to zip it all up, when I spotted the cause of the problem. My MAME install is a copy of the folder from my horizontal cab, although I created a fresh mame.ini. Anyway, I forgot I use a vertical.ini on my other cab, which sets the aspect ratio I prefer for vert games on a horizontal monitor. After deleting this file, all seems to work as it should.  :)
Sorry, my mistake (again).  :-[
« Reply #15 on: February 19, 2016, 07:54:50 am »
That was a relief for me  ;)
big10p
« Reply #16 on: February 19, 2016, 08:02:07 am »
Yeah, sorry for the false scare.  >:D  :laugh:
