Author Topic: What's the best arcade button?!!!!??  (Read 13889 times)
« on: February 17, 2016, 02:29:54 pm »
So the trend lately is to use LED buttons you can find everywhere that aren't concave. I can't stand them. I'm so used to concave that convex buttons feel so weird.
What do you guys think?
keilmillerjr
  • Web Developer.
Re: What's the best arcade button?!!!!??
« Reply #1 on: February 17, 2016, 02:43:20 pm »
I've had 3 types of buttons.
Happ concave - Loud, generic looking, works
Ultimarc gold leaf concave - Very quiet
Siemitsu PS14NK - Quiet with foam pads, Allows the adding of vinyl and or paint under the clear button part
Can't comment on other buttons because I have limited experience.
    • GroovyGameGear.com
« Reply #2 on: February 17, 2016, 03:29:51 pm »
My opinion on this is that it's mostly due to cost.  Those common buttons are inexpensive, they light up, you can add your own legend to the plunger, and with the proper switch, aren't too bad to use.  The reason I say that the cost is what makes them so popular, is because there are better, and more costly alternatives in convex, but they don't move from the shelves anywhere nearly as quickly as the inexpensive ones do.
« Reply #3 on: February 17, 2016, 04:25:02 pm »
Concave or GTFO. I've gotten rid of all the convex buttons I've owned.
johnrt
« Reply #4 on: February 17, 2016, 05:03:42 pm »
+1
And ditch the LED-buttons once and for all!
« Last Edit: March 04, 2016, 09:40:14 pm by johnrt »
  • Last login:Today at 01:53:33 pm
« Reply #5 on: February 17, 2016, 05:18:49 pm »
Not a fan of light coming from anywhere other than the screen, but I have convex buttons because I wanted to build something that leaned more toward new school.
They're ok, but I miss concave buttons in a straight six Street Fighter layout.
Your brain knows exactly where your fingers are resting on the concave buttons.
The convex ones are pretty much flat.  Sometimes I feel like I'm just mashing the general area of the buttons instead of pressing them.
If a game has more than 3 buttons, I find myself looking down at the controls much more often to make sure my fingers are in the right place.
IIRC someone on here once put a divot into their top center button to counter this (like the little ridge on the F&J keys on a keyboard).
If I build a dedicated shmup cab, I'll probably only do 3 buttons and will probably stick with convex.
Any other type, I'm going back to concave.
EDIT: I'll add that I've tried padding on the Japanese style buttons and it drives me nuts.  I need to feel the plunger bottom out or I just press harder.
paigeoliver
  • Awesome face!
« Reply #6 on: February 17, 2016, 05:34:29 pm »
I won't use anything other than a Happ button or a leaf switch button as anything besides a start button.
Protip: If you have to have that light up bling bling then use leaf switch buttons, they are available transparent and in a bunch of translucent colors.
I am redoing my mame cabinet right now and I am seriously tempted to go to all leaf buttons.
Token
« Reply #7 on: February 17, 2016, 09:42:58 pm »
If God didn't intend for us to use concave pushbuttons, then why are our fingertips convex?
« Reply #8 on: February 17, 2016, 09:50:40 pm »
Troof.
Amen.
gildahl
  • Last login:September 24, 2025, 10:32:51 pm
« Reply #9 on: February 18, 2016, 03:40:52 pm »
All concave, all leaf, no LEDs.
keilmillerjr
  • Web Developer.
« Reply #10 on: February 18, 2016, 10:11:13 pm »
I would assume that convex buttons will have better overall response times than concave buttons since you could land on the side of a concave button and slide or push with the edge of your finger. The advantage of concave that I can see would be that its easy to feel for finger placement. It's not like one is better than another as they both serve different purposes. Like economy grade brake pads and professional grade brake pads. Which would I choose? It depends.
bluelight
  • Last login:April 05, 2016, 11:01:57 am
« Reply #11 on: February 18, 2016, 10:20:58 pm »
I just ordered my buttons and they are all IL concave with 20g zippy microswitches. I went with those switches because they have the benefit of being lighter and more quiet, but not being leaf switches which I hear wear out quicker and get dirty. Also some of the leaf switch buttons I saw are sealed so you can't adjust them or clean them.. but I dont want something I would have to clean anyway.
I will let you know how I like my selection when I get them... but I figure they are as close to leaf as you can get without actually going leaf.
Also, they can always be switched to leafs later if you so desire.. you just would need to order the switches to swap out.
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« Reply #12 on: February 18, 2016, 10:47:45 pm »
Do you consider Happ and IL the same?
bluelight
« Reply #13 on: February 19, 2016, 02:28:54 am »
They are not the same anymore.
« Reply #14 on: February 19, 2016, 09:16:26 am »
... but not being leaf switches which I hear wear out quicker and get dirty. Also some of the leaf switch buttons I saw are sealed so you can't adjust them or clean them.. but I dont want something I would have to clean anyway.
This is a bit of a common misconception.  Any switch which claims to be a leaf, and cannot be adjusted or cleaned, is not a true leaf switch.  With a true leaf switch, the amount of wear is a product of the type of leaf button and/or whether the switches are properly positioned in relation to the button.  Frequent cleaning is a product of a worn switch.  Keep them from wearing, and you also keep them from needing to be cleaned.
Micros wear as well.  They just aren't serviceable (at least not as easily.)   Those, you just throw away and buy more. ;)
monkeybomb
« Reply #15 on: February 19, 2016, 06:02:24 pm »
That's actually why I was asking.  paigeoliver took a hard stance against anything that wasn't happ, but I don't know if IL fell out of favor to that degree, or if it was a given that the old happ IL buttons could live with current IL buttons that aren't from happ.  I haven't tried either since they split, so I was curious.
paigeoliver
  • Awesome face!
« Reply #16 on: February 22, 2016, 04:46:10 pm »
For new gear I have often taken a pretty hard stance that you either need to buy Happ/iL or don't even bother. This is based on a few different things.
Happ/iL gear is what everyone in the Americas grew up using and thus it is what they are used to. While Europe didn't get many games and what they did get was a mish-mash of control brands from all over the spectrum.
Happ/iL designs are a known quantity and generally built to an acceptable level of quality.
Meanwhile the alternative are Asian style controls. You didn't grow up with these unless you grew up in Japan. They feel completely different than western style controls and are far less heavy duty. In fact they are so much less durable that Japanese companies shipped western style controls with all their kits outside of Japan right up until the industry contracted into nothingness. Not only do they feel different and are less durable they also have different bolt patterns than American cabinets have and many (most?) of them are designed for metal panels, something that is hard for most home builders to construct.
I actually prefer microswitch based Wico joysticks and leaf buttons, but consider the Happ gear to be an acceptable alternative to that. If you don't know what stick to buy then buy a happ super.
I haven't had enough first hand experience with new product since the split from iL to really comment on the differences.
« Reply #17 on: February 22, 2016, 05:05:17 pm »
The IL joysticks are much smoother and less springy than their Happ counterparts, which is great for, say, 1942, but less desirable for Street Fighter Ii.
« Reply #18 on: February 22, 2016, 05:34:00 pm »
Wow, am I that old? (don't answer that.)  The HAPP/IL gear that most are using today, didn't really even hit the arcade scene until about 1987 when Street Fighter debuted.  I.e.  after the arcade heyday.
I grew up using gear from Wico, Atari, Betson, Williams, Midway and Namco, as well as some others which were less known (like Monroe Electronics.)  If folks went to the arcades in their youth to play fighting games, then they probably used the HAPP/IL sticks you see today.  Otherwise, they probably didn't grow up using them in the arcades.
When I lived in Europe for three plus years, I saw a lot of Suzo parts, and some which I would recognize as the HAPP/IL "Super" style.  That was a culture shock for me, after cutting my gaming teeth on other controls.  Made me homesick :).
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #19 on: February 22, 2016, 05:41:16 pm »
+1
Working: Not Enough
Projects: Too Many
Progress: None
paigeoliver
  • Awesome face!
« Reply #20 on: February 22, 2016, 05:57:05 pm »
Someone who turned 40 today would have been born in born in 1976 and would have been in their prime playing years during the period of time that the Wico stuff was vanishing and the Happ stuff was becoming standard.
I prefer the old stuff too, but it wasn't all great. Gottlieb used terrible sticks. Coin control sticks had cruddy plastic actuators that would break off and cause people to bend the sticks trying to get the thing to register movements. Classic Nintendo sticks combined everything bad about leaf sticks, microswitch sticks and manual transmission gearshifts into a package sized for a 4 year old child. Atari logo sticks were great, until the game got about 2 years old and they went all sloppy. Wico and Monroe however were so good.
I have to assume that there is no financially viable way to reproduce the wico or monroe designs today, or else you (or someone else) would already be doing it.
I once wasted a pair of Monroe sticks on a conversion game that I sold for $200.
« Reply #21 on: February 22, 2016, 07:00:28 pm »
Funny how that's the kind of stuff that sticks in your head.
« Reply #22 on: February 22, 2016, 08:39:58 pm »
Not sure how that relates.  Saying that X grew up with HAPP/IL would be making the assumption that all X ever played was fighting games.  The truth is, anyone who played everything but, probably didn't use the Happ/IL stuff much, if ever.
It's important to keep in mind that the classic controls lived through the heyday of the arcades, and were used mercilessly.  I'd venture to guess that any one of those designs would last well over a decade in most home gaming environments (with some occasional maintenance and part replacements.)  But no mechanical devices are going to last forever.  One of the most robust sticks I have had the pleasure to purchase and examine was the Williams 49-way.  Yes, the centering spider wore out, but the rest is built quite literally like it was designed to survive a nuclear winter.
All you need is 20 - 25k  and a dream :)  But, I wouldn't drop that kind of investment on an exact duplicate.  There are improvements which can be made, and think I have come pretty darn close, if not exceeded the design a bit.  But no matter what, it's costly because whether it's a hand-built custom stick, or the need to recoup huge mold and short run metal components costs, it still must be paid for.  So yes, for the price, the HAPP/IL sticks are a good value.  But they really aren't what those who played a lot of the originals used, and much better options are out there for those who can swing the cost.
Ouch.  :)
Xiaou2
  • Last login:February 17, 2026, 10:25:21 pm
  • NOM NOM NOM
« Reply #23 on: February 22, 2016, 08:43:48 pm »
Monroe sticks are kinda cool.  Their biggest problem was that the pivot ball could get gunked up and rusted / stuck in place.
(Metal ball to metal housing)    Then again, I only know this because of the used ones that I had picked up.  Maybe they had sat out in some warehouse with high moisture...   and possible didnt have such a problem in the arcades.
 The thicker shaft was a bit odd too.  But, when they were working good, they really made Time Pilot and Gyruss play smooth.
 In some respects, the Japanese sticks resemble them, with their center pivot ball and small footprint.  However, as you said,
the Japanese sticks are in fact really low durability, compared to western sticks.  The throw is often too short, and IMO, leafs feel and play 1000x better for classic games.
 I still prefer the feel of the Wico 8way leafs..   though, now Im curious to see how well the Monroes would perform with Robotron.
 I never got to restore the sticks, and try them out thoroughly.   =(
 I also remember the Nintendo Sticks.   Tiny, but surprisingly long throw.  Very sloppy and mechanically clunky.    Then again, a lot of their games, like Donkey Kong, DKJR.. etc, were also Clunky and Slow moving.   heh
 Im 42 now... so I played a great majority of the Classic era games on original hardware.   Of course, you dont always appreciate that when you are young and have never seen the inside of a cabinet.
 I didnt learn the differences in controller types in depth,  until I became a manager at an Arcade.   At the time I came in... leafs were just about phased out.  Only a few games in the arcade had them.    Maybe it was around 1998...  Its hard to recall now.
 At that time, there were some really funky microswitch sticks.  Some that resembled happs... but they used slightly different parts.  Most were awful,  and it was hard to find part to rebuild them with, due to their similarities.. yet varied evolutionary changes.
 The Happs sticks that started to come in new, at that time, were Ultimates.    They worked good for a few months... but then the plastic spacers would Shred themselves to death.. and have to be flipped over.   You would see a pile of plastic dust in the control panel from them!
 Finally, the Happs Competitions came out... and wow, what a difference.   They lasted so much longer...  not nearly as aggressive on spacer shredding.  They were a godsend, saving me tons of maintenance work.
 I also remember the Wico Microswitch balltops.  We had one machine that used them... and I recall them feeling really nice.   Actually, they were more durable and better playing than those wretched Ultimates.   However, they were pretty much phased out of stock by then.
 If I recall correctly,  the Wico Microswitch balltops used the same rubber grommet centering system.  Much smoother, quieter, and less  end-of-travel "bump-fatigue".
 I wish I could tell my former self, to save those spare leaf parts.   The District Mgr. said to toss them, and most of the rest of the unused "obsolete"  parts, that were taking up shelf space.   >_<
 Even at that time... while I knew of the mechanical differences in leafs and micros...  I didnt fully appreciate the difference.   The leafs I was repairing at the time, were old and fatigued,  .. so maintenance was high with them.   I got ticked off, at an already high workload of repairs...   and didnt know why Leafs should be kept in certain machines.
 One day I decided to replaces all remaining leaf games with micros.   I thought... this is going to be sooooo much better.   Less work for me... less customer complaints... and customer compliments on the new controls!
 Nope.    Immediately people who played Galaga and some of the others... were not happy.    The control and feel in micros is far different.
Only then did I 'start' to realize their value.
 But the thing that really drove it home... was playing a Real Robotron machine about 5? years ago... with real Wico 8way leafs.
 I didnt care for the game much when I was young... cause it raped me of my money in mere seconds.   But now, I was older,  more coordinated... and was able to hang in there for a while.   I totally got hooked on it, dumping quarters in it for several hours at a time on the weekends.   Highest level I got to was probably about 32,  and I was laughing, sweating, panicking, and giggling like a little kid... the whole time!   I quickly preferring it to Smash TV... as it is FAR more adrenalin intense, and far more skill-balanced.  (Not an unfair 'continue' based quarter-eater)
 Not much later, I had played Robotron on someones Multi-Jamma cab... it was with Micros.. and it was Wretchedly unplayable.  I walked away after one bad game...  and instantly went to ebay to snap up what remaining NOS Wico 8 ways leaf sticks that I could find.
 (For the record... I also had tried to play with typical PS2 style gamepads.. trying both directionals, as well as the mini-analogs.  Neither were quick enough for that games intensity)
 I still wouldnt fully appreciate Leaf buttons... until playing and later owning, an Asteroids Deluxe.   The key here.. was learning about "Floating"  (vibrating)  the leafs contacts... rather than fully depressing them all the time.
 Once I understood that method...   It caused me to completely re-think my whole Mame cabinet designs.  Classics, especially rapid-fire  (Halleys Comet, Asteroid Deluxe)   or  long-repeated-firing games (like Galaga) ... really need a Leaf... or your fingers/hand will fatigue in mere minutes of play.
 (More recent Arcade games started making all shooters have Auto-Fire, as standard... probably due to no more leaf button availability / use.  While this works fine... it does rob you of an additional challenge that could have been had,  making the games more easy.   Then again, they added a "Continue"... so it really didnt matter what difficulty there was... as you now buy your victory, rather than earn it through practice and developed skills)
 My Suggestion, is to include at least One real classic Leaf button on your control panels.  Maybe place it as the 7th button, diagonally downwards in front of the typical fighter 3x3 layout rows.
 As for sticks.. I recommend using 2 sticks per player.   You can place a 2nd stick almost vertically above the typical stick position.  Just move the top most stick a little inwards, at a slight diagonal.   It will allow you to use either stick comfortably, and will barely take up much more space:
_____________________
_                                      _
_      (o)                            _
_                        O O O     _
_           (o)         O O O    _
_                      O              _
 You can space them vertically almost touching.  Maybe a cm needed at most.   Just need a little diagonal separation,  so that the sticks do not get in the way of each other when gripped and rolled around.
 Of course, you could also do typical swappable controls / panels / multiple machines...etc.
 This layout also wouldnt solve the 4way issue... as true 4 way physically restricted sticks are the Only way to play games like Ms.Pacman.
« Last Edit: February 22, 2016, 08:52:42 pm by Xiaou2 »
