Author Topic: SF2 Arcade Cabinet + Plans and Art  (Read 7009 times)
a_netanel
  • Last login:August 28, 2022, 11:40:07 am
« on: February 16, 2016, 09:57:56 am »
This is a cabinet that I finished a few months ago.
While I used the forum's resources, I was not in a state of mind to document everything and open a progress thread.
But, hopefully someone will find something useful in my plans and artwork files (The artwork is hardly original. Merely tweaks on the SF2 art that is circulating here).
The print was done by Brad (Lucian), and it was magnificent.
I'll be happy to help anyone who want to use this material.
Enjoy.
Artwork:
https://dl.dropboxusercontent.com/u/52657948/Arcade%20Cabinet/Art/Art.7z
Plans:
https://dl.dropboxusercontent.com/u/52657948/Arcade%20Cabinet/Plans/Plans.7z
acvieluf
  • Last login:February 10, 2026, 08:01:11 pm
Re: SF2 Arcade Cabinet + Plans and Art
« Reply #1 on: February 16, 2016, 10:31:25 am »
Wow!  Nice work!   :applaud:
Alaska
  • Last login:January 02, 2025, 06:25:46 pm
  • Fight inflation not farmers
« Reply #2 on: February 16, 2016, 12:28:35 pm »
Thanks for sharing!! Killer build!! :cheers:
big10p
  • Mmmm, arcade classics!
« Reply #3 on: February 16, 2016, 01:14:14 pm »
Not my kind of cab or game, but still a very impressive build! Just in time for the SF 25th anniversary, too.  ;D
kattastik
  • Last login:November 03, 2016, 05:59:17 pm
« Reply #4 on: February 16, 2016, 09:49:30 pm »
I love this! Do you have any more photos or info on this or the build? I'm starting my next one soon and I may totally use this as a blueprint.
vaderag
  • Last login:May 07, 2025, 11:33:07 am
  • Building my own cab :)
« Reply #5 on: February 17, 2016, 05:59:23 am »
Mate - thank you so much.
I'm just looking to start my build and was leaning towards a SF theme. Still not sure that I will go with an SF theme but at least your artwork will give me a base for my design.
Cab looks awesome. Thank you again!
« Reply #6 on: February 17, 2016, 07:54:41 am »
Great of you to share your art and plans. Even better that you shared the PSDs, have the layers grouped, and used a clipping mask instead of cutting into the character files  :applaud:
Alaska
« Reply #7 on: February 17, 2016, 02:22:43 pm »
What are the dimensions of the monitor you used for this cab?
a_netanel
« Reply #8 on: February 17, 2016, 02:26:05 pm »
I've uploaded some pictures to a Dropbox Album:
https://www.dropbox.com/sc/umaosjlsribyiv3/AADzl2onq9l0b6zdTV-qyRgYa
Few things that I had to learn the hard way:
 - Don't use simple spray paint directly on Formaica... It peels off with every small hit and scratch. Use good primer and paint (I used a roller to apply it).
 - When trying to remove said paint, don't waste time and sand paper. Paint thinner is your friend!
 - If you can, use water based primer and paint. Soooooo much easier to clean your tools, hand and surrounding.
 - When cutting doors, plan for a small gap between the door and the panel, and cut the door slightly shorter. Perfect fit exists only in CAD ;)
 - Don't skimp on the joysticks and buttons. You can feel the difference between super cheap ones and even "normal" quality joysticks like Zippy.
a_netanel
« Reply #9 on: February 17, 2016, 02:28:59 pm »
Its a Samsung T260, 26" monitor:
http://www.cnet.com/products/samsung-syncmaster-t260-lcd-monitor-25-5/specs/
fablog
  • Last login:January 04, 2026, 04:27:15 pm
« Reply #10 on: February 17, 2016, 07:41:18 pm »
Very good job mate! I'm looking for small round speaker covers like yours...what's the dimensions and the shop you bought them?
Thx
a_netanel
« Reply #11 on: February 18, 2016, 02:14:14 am »
Thx
Hete you go:
http://www.ebay.com/itm/NEW-DIY-2pcs-Red-3-inch-Circle-Speaker-Decorative-Circle-With-Protective-Grille-/111773043642?hash=item1a06314bba
fablog
« Reply #12 on: February 21, 2016, 12:51:33 am »
Thank you :)
paigeoliver
  • Awesome face!
« Reply #13 on: February 21, 2016, 02:27:28 pm »
What are the little protrusions on the front of the panel?
Slippyblade
« Reply #14 on: February 21, 2016, 03:18:41 pm »
I just took a quick glance at the cut diagrams and I think they are drawer pulls.  I think that's a keyboard drawer.
a_netanel
« Reply #15 on: February 22, 2016, 02:12:39 am »
Its the Volume and Bass knobs.
I took apart an Altec Lansing vs2621 speakers and mounted the circuit board inside the control panel box, with hot glue and a small piece of wood.
« Last Edit: February 24, 2016, 05:56:42 pm by a_netanel »
ivwshane
    • My first mame cab! (WIP)
« Reply #16 on: February 24, 2016, 02:53:57 pm »
Nice job! I can't pull up the plans right this minute but what is the height and width of the cab?
a_netanel
« Reply #17 on: February 24, 2016, 06:00:43 pm »
Height (without wheels) - 178 cm.
Width - 68 cm.
Depth (back to front of control panel) - 55 cm.
