Author Topic: Help compiling retroarch under Groovyarcade  (Read 3543 times)
pakoman
  • Last login:November 05, 2024, 08:36:26 am
« on: February 11, 2016, 02:05:20 pm »
Hi,
I want to add N64, PSP and DC support to Groovyarcade.
I'm trying under a virtualbox installation of Groovyarcade for 64 bits. It has access to internet but when I type "git clone git://github.com/libretro/libretro-super.git" y get "bash: git: command not found" error.
I tried to copy the files of Retroarch from Lakka distribution, but I get this error when I run Retroarch:
"Didn't read whole file: /sys/devices/system/cpu/pressent.
Didn't read whole file: /sys/devices/system/cpu/possible."
What should I do to compile under Groovyarcade environment?
Regards.
donluca
  • Last login:December 02, 2025, 11:41:03 am
Re: Help compiling retroarch under Groovyarcade
« Reply #1 on: February 11, 2016, 09:18:55 pm »
Looks like git is not installed in the Groovyarcade distro.
I'm pretty sure there's a package manager though, which distro is GA built upon?
2.- Inflatable dolls
Doozer
  • Z80 ERROR
« Reply #2 on: February 12, 2016, 05:05:05 am »
GA is built upon Arch Linux. The package manager is 'pacman'. You can type 'pacman -Syyu' to update it.
pakoman
« Reply #3 on: February 12, 2016, 02:39:44 pm »
Thanks, I typed that and I think it's now downloading and updating all Linux packages already in the system.
What should I type to download from a repository or compile Retroarch?
« Last Edit: February 12, 2016, 03:49:03 pm by pakoman »
donluca
« Reply #4 on: February 12, 2016, 06:37:31 pm »
pacman --help
should give you all the information you need.
Or you can always do
man pacman
and open the manual ;)
pakoman
« Reply #5 on: February 16, 2016, 04:09:52 pm »
I've gone a bit further but still no luck.
I managed to to compile and install apacman:
wget https://aur.archlinux.org/cgit/aur.git/snapshot/apacman.tar.gz
tar xzf apacman
cd apacman
makepkg -si
and then install SDL2:
apacman -S sdl2
Bue when I try with Retroarch, it downloads everything start checking the source files and then it gives an error when 'LD retroarch' line appears it gives a lot of undefined references and makefile 124 recipe for target 'retroarch' failed:
apacman -S retroarch-rbp-git
If I use:
pacman -S sdl2-git
pacman -S retroarch-git
it works for SDL but does not found retroarch-git :(
