Author Topic: Tightest radius to form T-molding around?  (Read 2415 times)
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
« on: January 13, 2004, 09:01:17 am »
My CP has a couple of 90 degree angles on it.
I know that t-molding can be "cut" on it's insertable tongue to get it around corners, but I'm probably dreaming if I think I can get it around a perfectly square 90.
What radius should I apply to the corners?
Thanks.
%$#@!&* machine took my quarter!
Re:Tightest radius to form T-molding around?
« Reply #1 on: January 13, 2004, 09:08:02 am »
I would think a half inch radius would be enough.  Would probably look nice, too.
Minwah
    • MAMEWAH
« Reply #2 on: January 13, 2004, 10:31:39 am »
I used 30mm radiuses on most of my corners.  I expect that is a fair bit more than required tho...I'd say maybe 10mm absolute minumum, go for more if possible.
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #3 on: January 13, 2004, 11:22:15 am »
I got my molding around 90 degree corners just fine on my cabinet.  But it does take a little practice to get the cut right.  On a controller, rounded edges look nicer to me, too, and that'll make your T-molding go on a lot easier.
eightbit
  • Last login:September 07, 2019, 07:38:11 pm
  • My cab is never done...
« Reply #4 on: January 13, 2004, 09:12:17 pm »
It can bend a 90 perfectly easily, just depends on what look you want. Many arcade cabs had 90' corners.
My statements are my own opinions. They have the value that the reader gives them. My opinion of my opinion varies between foolish and brilliant and these opinions often change with new information.
OSCAR
  • Last login:September 06, 2018, 11:31:53 pm
  • I think Bigfoot is blurry, that's the problem...
    • Oscar Controls
« Reply #5 on: January 13, 2004, 09:16:20 pm »
No, you're not dreaming, its very feasible...  :)
Here's what the 90deg corners look like on my upright MAME cab:
http://www.oscarcontrols.com/tmp/tmold-corner.jpg
Minwah
    • MAMEWAH
« Reply #6 on: January 14, 2004, 04:54:43 am »
Looks great :)  At least it should be easy for me to get it around my huge 30mm radius's (ray-dee-eye?)  ;D
