Author Topic: Romlister issue. Blank merged xml  (Read 1429 times)
bobmoo79
  • Last login:September 06, 2023, 09:06:46 am
« on: February 04, 2016, 09:05:00 am »
Hi there, I've just downloaded the latest name 0.170 and unfortunately cannot get romlister to spit out the merged xml correctly. Are there any known issues with this version mame? If I point the merge tool to mame64exe it does create the listxml fine. I then select the latest versions of nplayers, catver, controls.xml and click "merge" but after a very short while I'm left with a merged xml file that is empty. I Must be doing something wrong but I'm not sure what.
Edit: I just tried mame 0.169 and it still didn't work. Any ideas?
Bob
Sent from my iPhone
bobmoo79
Re: Romlister issue. Blank merged xml
« Reply #1 on: February 04, 2016, 04:01:26 pm »
Problem solved. I was accidentally using an old version of romlister.
