Author Topic: Screen 'bloom' with CRT emudriver v2  (Read 2176 times)
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
« on: January 31, 2016, 01:14:08 pm »
Hi
I'm getting a strange over-brightness/blooming on my monitor (Hantarex MTC9000) since upgrading to CRT emudriver v2. I realize this issue is unlikely to be caused by CRT emudriver itself, but wondered if anyone else has the same issue with a similar setup to mine? My monitor is connected via a JPAC.
At first, I figured it must be down to no longer using a VGA cable with resistors to force monitor detection, so I turned down the screen drive pot (on the back of the flyback) as well as the brightness preset pot on the chassis. I also turned down the RGB cutoff and gain pots to a minimum, on the neck card. Although this had the expected affect of darkening the screen, the white areas still bloom and bleed badly (see pic). Most noticeable on the scrollbars.
If I use my old cable (with the resistors), it's fine, but I'd rather not use that as it causes other issues I won't go into here. The JPAC has a video amp so wondered if this is causing it?
Anyone else had this issue or can suggest a solution? It's got me scratching my head as there aren't any other controls on my monitor that I can adjust.
Thanks.
Calamity
  • Moderator
  • Last login:Today at 06:10:10 am
  • Quote me with care
Re: Screen 'bloom' with CRT emudriver v2
« Reply #1 on: January 31, 2016, 01:43:54 pm »
You need to adjust the contrast pot, it's on the chassis left corner, looking from the back.
Steps to create a log:
big10p
« Reply #2 on: January 31, 2016, 01:51:45 pm »
Oh dear God! I completely forgot about that. Sorry for being such a numpty.  :-[
Thank you!
« Last Edit: January 31, 2016, 02:02:56 pm by big10p »
