Author Topic: Mortal Kombat 2 Build  (Read 4391 times)
Cobolisdead
« on: January 29, 2016, 02:25:36 pm »
So I got inspired, and I found  cheap Mortal Kombat II PCB on Ebay. I got just the board itself, but it looks like that I will need a sound board as well. Here is the link to what I got, anything else that I will need?  I know that I will need a Kick harness, Jamma Harness, a power supply, Monitor, Cab, art, joysticks, and buttons.
http://www.ebay.com/itm/Untested-Mortal-Kombat-2-Arcade-Game-Board-See-Photos-/141884394868?_trksid=p2047675.l2557&ssPageName=STRK%3AMEBIDX%3AIT&nma=true&si=41rPPVewug4rdpSHzbjL5Fk3HFo%253D&orig_cvip=true&rt=nc
So I guess that this will be my next project after the Simpsons.
Re: Mortal Kombat 2 Build
« Reply #1 on: January 29, 2016, 03:34:42 pm »
You'll need a volume pot as well.
Cobolisdead
« Reply #2 on: January 29, 2016, 04:55:55 pm »
That's not on the sound board?
« Reply #3 on: January 29, 2016, 05:02:01 pm »
Nope. I had to make my own when I got an NBA Jam board that was missing it. You can get one from Bob Roberts, too.
MK3FAN
« Reply #4 on: January 29, 2016, 09:02:03 pm »
MK2 does not use a volume pot.
Cobolisdead
« Reply #5 on: January 29, 2016, 09:03:44 pm »
Can you use a  MK1 Harness on a MK2 PCB?
« Reply #6 on: January 29, 2016, 09:16:14 pm »
For some reason,  I didn't see the II. Listen to MK3FAN.
Cobolisdead
« Reply #7 on: January 30, 2016, 11:22:21 am »
So looking at these two pages, it seems that Mortal Kombat 1 and 2 use different connectors for the kick harness.
MK1:
http://www.mikesarcade.com/cgi-bin/spies.cgi?action=url&type=pinout&page=MortalKombat.html
MK2:
http://www.arcade-museum.com/pinouts-game/8756.html
So that means a MK1 Harness can't be used with a MK2 board. :(
MK3FAN
« Reply #8 on: January 30, 2016, 06:01:24 pm »
If your MK1 is a T-Unit, it will use the same harness as MK2. If it's a Y-Unit, yes, you'll need the separate ones.
Cobolisdead
« Reply #9 on: January 30, 2016, 09:13:28 pm »
So I found a MK4 cab about three hours away from here, and it works but has monitor issues. I am tempted to gamble the $450 and gas money to get it to see if I can make a multi-game out of it.
« Reply #10 on: January 31, 2016, 04:43:21 pm »
Around these parts (midwest) it's not easy to find a Midway MK cabinet.
« Reply #11 on: January 31, 2016, 05:10:41 pm »
drive up to DE, I'll give you an empty MK4 cab for free
« Reply #12 on: January 31, 2016, 07:09:57 pm »
What highway do I take to get to Denmark?!
« Reply #13 on: January 31, 2016, 07:11:36 pm »
I-95 =D
Cobolisdead
« Reply #14 on: January 31, 2016, 07:16:41 pm »
That is a very tempting offer!
Cobolisdead
« Reply #15 on: February 01, 2016, 10:25:19 am »
So when the board get here, can I test it by putting it into my Simpsons cabinet since they are both JAMMA? I just want to see if it boots up.
« Reply #16 on: February 01, 2016, 10:26:51 am »
Keep in mind MK uses -5V so if you don't have that run in the Simpsons harness (doubtful) you'll probably have no sound, though MK3FAN or Malenko could speak more accurately to the topic.
Cobolisdead
« Reply #17 on: February 01, 2016, 10:48:13 am »
Well, I don't have the sound board, just the main PCB is on its way from Ebay untested. I paid a fairly cheap price for it, so I am hoping that it works or I can easily fix or have it repaired. I just want to see if it the main PCB works.
« Reply #18 on: February 01, 2016, 01:00:39 pm »
This is accurate, but you can add the -5V to your edge connector easily enough.
Cobolisdead
« Reply #19 on: February 01, 2016, 04:54:11 pm »
So to clarify, if I plug the Mortal Kombat II PCB, with no sound board just the Main PCB, into my Jamma machine, I should be able to see if it boots up correct?
MK3FAN
« Reply #20 on: February 01, 2016, 05:17:07 pm »
Yup.
Cobolisdead
« Reply #21 on: February 02, 2016, 08:25:48 am »
Awesome!
