Author Topic: Rowe ami r-83 disco control lights not working!!!  (Read 7533 times)
Sherahmed_1985
  • Last login:January 29, 2016, 02:26:46 am
« on: January 29, 2016, 02:26:46 am »
Hi all
I have recently been called in to check up on my bosses Rowe ami r83 disco 200 jukebox. It plays well and is a very nice machine. I have however found that the disco control unit is not making the front lights display and sequence flash as it should. I have seen the board and pin congfigurations and I think I am missing the 30vdc to the p2-6 pin out . Were can I find the 30vdc for that pin. I had found 2 wires black and red that are on the p2 plug but when u trace them it was found loose in the cabinet not connected. I really would appreciate any assistance on this as this is my first time doing a breakdown on a jukebox. I have attached a photo of the board.
Smithie
  • Last login:February 22, 2016, 08:32:06 am
  • Be yourself; everyone else is already taken
Re: Rowe ami r-83 disco control lights not working!!!
« Reply #1 on: February 03, 2016, 05:55:29 pm »
Hi Mr.....No Name :-).... maybe this may be helpfull to you? good luck
jefferson1975
  • Last login:May 08, 2020, 12:29:09 pm
« Reply #2 on: February 21, 2017, 03:34:47 pm »
Hello,
I have a R-83 Disco 200. It looks like the light assembly box is missing on the left hand side. The lights are stuck in the on position. Does anybody know where I can get a light assembly that will allow me to flash the lights, etc.
Jeff
Ken Layton
  • Guru
  • Technician
« Reply #3 on: February 21, 2017, 04:27:33 pm »
Bruce Wentworth at A & B Jukebox Repair should be able to sell you the light controller assembly:
http://rowejukeboxparts.com/
jefferson1975
« Reply #4 on: February 21, 2017, 08:58:17 pm »
Thank you for the response. I contacted Bruce last week and he doesn't have it. Any other ideas? Thank you!
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #5 on: February 22, 2017, 08:59:29 am »
Hello Jefferson1975,
I have one for sale on Ebay, but I am in the UK.
Here is the item number
Item number: 321740957386
Regards
Alan
Alan Hood
ami-man
UK
jefferson1975
« Reply #6 on: February 22, 2017, 02:35:34 pm »
This looks great. I'd like to purchase. Will it work on the R-83? Right now the lights are plugged into the "lights" input on the power supply box. How does this item hook up? Will I need extra lighting cable, etc. Thank you for your help.
ami-man
« Reply #7 on: February 26, 2017, 06:21:12 am »
Sorry it was an R-84 light controller that I had for sale.
If I get offered one on the R-83 controllers I will contact you, sadly they do not turn up very often.
Regards
Alan
Alan Hood
ami-man
UK
jefferson1975
« Reply #8 on: March 14, 2017, 02:58:34 pm »
Hello,
I was able to get the lighting control unit. However, I have no idea how to hook it up. Right now, the lights are just plugged into the power supply. Any insight would be much appreciated.
Jeff
ami-man
« Reply #9 on: March 16, 2017, 11:15:26 am »
Hi Jeff,
You will need to make two looms one for the 120 volts ac output on connection P1 on the board and the input signal from the amplifier auxillary connections and 30 volts dc and ground from the mute connection plug. This is connection P2 on the board.
If you download the R-83 Disco 200 supplement link already given earlier in the topic, look at the schematic on page 14 this should give you an insight.
Regards
Alan
Alan Hood
ami-man
UK
jefferson1975
« Reply #10 on: May 23, 2017, 11:15:22 am »
Sorry... I have some time so I'd like to work on this again. I'm still a bit confused. Can you tell me exactly where the cords coming out of P1 and P2 go into?  Any insight would be greatly appreciated. The schematic doesn't make much sense to me. Thanks again for your help.
Jeff
jefferson1975
« Reply #11 on: June 22, 2017, 01:24:53 pm »
Does anybody have the wires I need to connect the lighting control unit?  Please see ami-man response from March 16th above.
Jeff
