Author Topic: CP Wiring question  (Read 3112 times)
acvieluf
  • Last login:February 10, 2026, 08:01:11 pm
CP Wiring question
« on: January 27, 2016, 08:31:55 pm »
I ordered a wiring kit with my controls, from The Playdium Store, but I think something is off. I remember reading that the ground wires should be a thicker gauge than the other wires. But in the kit I got, they're all the same thickness.
I can find (and have found) what the gauge rating should be, but will it hurt if the grounds are thicker? (Assuming they're not daisy chained. Is it different if they are?)
Here's a picture:
Sent from my Atari 2600
Osirus23
Re: CP Wiring question
« Reply #1 on: January 27, 2016, 08:50:17 pm »
Should be fine. I don't use thicker wire for grounds. A lot of people have used Ethernet cables for CPs and those conductors are tiny compared to what you have there.
acvieluf
« Reply #2 on: January 27, 2016, 08:55:11 pm »
AWESOME! THANKS!
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: January 27, 2016, 09:24:50 pm »
I don't think I have ever heard that bit of advice before. Wires for power (including power ground) are usually thicker, but not controls.
I don't often see folks getting their gear from Playdium Store -- are you here in the big smoke?
Working: Not Enough
Projects: Too Many
Progress: None
acvieluf
« Reply #4 on: January 27, 2016, 09:32:34 pm »
I'm sorry, what's the big smoke?
CheffoJeffo
« Reply #5 on: January 27, 2016, 09:33:39 pm »
Sorry -- Toronto. Probably means you aren't here.
Working: Not Enough
Projects: Too Many
Progress: None
acvieluf
« Reply #6 on: January 27, 2016, 09:34:03 pm »
Nope. Nova Scotia.
acvieluf
« Reply #7 on: January 27, 2016, 09:34:51 pm »
So you're saying I should follow what I've read, and use thicker wires for ground?
CheffoJeffo
« Reply #8 on: January 27, 2016, 09:43:01 pm »
No -- I'm saying I have never heard that advice for connecting controls and never seen an example of it in any cab I have ever seen.
The rest was just me trying to figure out what somebody might have said that ended up with the interpretation you cite.
Hook up with what you have -- you'll be fine.
Working: Not Enough
Projects: Too Many
Progress: None
acvieluf
« Reply #9 on: January 27, 2016, 09:49:52 pm »
Oh OK, sorry for my confusion. Thanks again.
CheffoJeffo
« Reply #10 on: January 27, 2016, 09:50:35 pm »
I have that effect on people.  ;)
Working: Not Enough
Projects: Too Many
Progress: None
acvieluf
« Reply #11 on: January 28, 2016, 08:35:07 am »
One more question about wiring it up, if i may.  I noticed the ipac only has one (two? i can't remember at the moment) place for a ground.  If i'm not daisy chaining them, where would i run all of the ground wires to?  Is there a common solution to this?  It seems like running 23 or so wires to a metal screw would get too crowded to work?
What to the experts usually do?
« Reply #12 on: January 28, 2016, 08:40:55 am »
They daisy chain the ground. Just buy a $7 JAMMA loom off of ebay and cut the connector off. BAM, instant wiring kit with daisy chained grounds and bonus, all the wires have QCs on the end.
« Reply #13 on: January 28, 2016, 09:55:45 am »
Why wouldn't you daisy chain the ground?
Malenko ' s advice is sound.
acvieluf
« Reply #14 on: January 28, 2016, 10:17:11 am »
Well, i didn't think i could.  But i realized (after you two's prodding) that there's no reason i couldn't just construct my own daisy chain, using the wiring i already have.  Because you're right, there's really no reason not to.  The $7 Jamma harness isn't necessary, and it ends up being close to $40 CAD by the time it gets to my door.  But thats ok.  I'll make one and work it out that way.  Thanks again, guys.
« Reply #15 on: January 28, 2016, 11:00:25 am »
if you get one from China its about $12CAD but you have to wait. If youre going to make your own that's even better , just put 2 wires into the QC before you crimp it down. Its easy but tedious work.I stopped crimping my own lines and just get the cheap ebay looms because the edge connectors on those are garbage but I don't use the edge connector anyway.
You could just strip and twist all the ground ends together and put a wire nut on it, looks like ---steaming pile of meadow muffin--- but is just as functional.
« Reply #16 on: January 28, 2016, 11:11:06 am »
I used to roll my own too. But save yourself the time and just get a pre done daisy chain for future projects. Your hands and your sanity will thank you for it. The cheap Chinese harnesses are great for everything but the power wires. Stay away from those power wires. I actually had some melt on me in Janky Kong.
