Author Topic: Happ Button to Power Arcade PC  (Read 1406 times)
majoly
  • Last login:February 11, 2016, 03:51:11 pm
« on: January 27, 2016, 03:56:33 pm »
Ok so my setup is when my PC is booting, everything comes up with my smart power strip.
Right now what I want to do is to use one of my Happ button to turn on the PC.
Of course with the microswitch that usually comes with this button it's impossible. Either I wire the cable to be always on, which is not what I want, or I hold the button pressed to have power to the PC.
Is there a micro switch that fits on Happ buttons that will turn and keep on my PC or is there a way to wire what I have to make it work?
Re: Happ Button to Power Arcade PC
« Reply #1 on: January 27, 2016, 04:05:17 pm »
What kind of PC is it?  Most modern PC's now use ATX power supplies which use a momentary power button on the front of the case.  You can tap into those two wires and use a standard Happ button.
If not, you can use a pushbutton like this one that will "stay on" when depressed:
http://www.ebay.com/itm/like/221878357446?ul_noapp=true&chn=ps&lpid=82
D
matsadona
« Reply #2 on: January 28, 2016, 07:54:55 am »
It is perfectly doable - I know since I have had this setup since 2007. I have done exactly as DeLuSioNal29 says. One touch it powers up (and with a smart strip i also powers up monitor, amp and lights). A second touch and everything shuts down.
majoly
« Reply #3 on: February 01, 2016, 07:48:00 am »
Yes you guys were right. My PC is a recent ATX computer, but when I tested my button, i tried it on an old At computer. I forgot my button would be ok with ATX when I tested.
Button is installed and wired to my computer, works great.
Thanks for the help :)
