Author Topic: My new artwork  (Read 6115 times)
quakebo
  • Last login:January 30, 2023, 02:13:01 pm
My new artwork
« on: January 22, 2016, 04:37:41 pm »
I have a bartop I built and this is my new artwork I am making what do you think.  Also where is a good place in the uk to get it printed.
control panel
marquee
side artwork
« Last Edit: January 23, 2016, 10:06:49 am by quakebo »
MartyKong
  • Last login:January 09, 2026, 12:25:53 pm
Re: My new artwork
« Reply #1 on: January 23, 2016, 09:01:50 pm »
I'm a real newbie at artwork so this is just my opinion. Is there a way to connect the side, cp and marquee artwork so it follows a theme? Which do you like best CP - Pac man theme, side artwork...?
Try to create the art so side, cp and marquee have a common theme.
quakebo
Re: My new artwork
« Reply #2 on: January 24, 2016, 04:45:03 am »
Thanks for that.  The trouble is I like all three of them so that is why I was thinking of going with no theme just what I like.
Ramakers
  • Last login:January 13, 2020, 01:20:43 pm
Re: My new artwork
« Reply #3 on: January 24, 2016, 07:50:32 am »
What you put on your artwork is totally up to you, I'm more into simple designs but yours feel nice. I love the CP with as I think one ghost for single player and two ghosts for two player game?
I'm only worried about the quality of the pictures you use. I don't know how good the images are you have, but the links you share are not even close to what you need to print them in full size. And take in mind that upscaling is no option. You need a hires image to start with. 200 dpi is good resolution to use, its nice when printed on industrial inkjet printers and the file size is manageable.
Token
Re: My new artwork
« Reply #4 on: January 24, 2016, 08:04:58 am »
I'm not crazy about the collage-o-characters approach to cabinet art. But if you are set on that, then make them all look like were drawn together. On your side art, the style of the bottom section doesn't match the top characters.
quakebo
Re: My new artwork
« Reply #5 on: January 24, 2016, 08:57:12 am »
Thanks, all advice welcome.  where to get good quality images to start with?
« Last Edit: January 24, 2016, 11:19:24 am by quakebo »
Ramakers
Re: My new artwork
« Reply #6 on: January 25, 2016, 02:06:14 pm »
I made quick effort on your CP.  But the ghosts need some attention.
here is a link to the original file:
https://c2.staticflickr.com/2/1645/24583181316_c3f9658a1a_o.jpg
What do you think of this side art. If you like I can help you adjusting it to your dimensions.
Merquee:
« Last Edit: January 25, 2016, 02:29:49 pm by Ramakers »
quakebo
Re: My new artwork
« Reply #7 on: January 25, 2016, 07:04:15 pm »
Thanks those look good. I am still deciding what I want but I have also come up with these.
marquee
control pannel
just need side art.
  • Last login:Today at 06:20:48 pm
Re: My new artwork
« Reply #8 on: January 25, 2016, 07:15:12 pm »
That squished control panel looks horrible. Troof.
mike boss
Re: My new artwork
« Reply #9 on: January 25, 2016, 09:16:41 pm »
The images are all cluttered, and over and above that the resolutions seem off.
Everything looks kinda muddled and pixelated.
I'd say refine your design, clean it up...less is more !
Re: My new artwork
« Reply #10 on: January 25, 2016, 09:20:17 pm »
Or just hire someone like Mike Boss to help you.  Art is just as important of an expense as the PC or controls you put into the cabinet.
Token
Re: My new artwork
« Reply #11 on: January 25, 2016, 09:36:17 pm »
Keep characters off the CP. You'll inevitably end up with a joystick coming out of Ryu's crotch.
vwalbridge
Re: My new artwork
« Reply #12 on: January 25, 2016, 09:53:20 pm »
You say that like it's a bad thing?
  • Last login:Today at 04:49:10 am
Re: My new artwork
« Reply #13 on: January 25, 2016, 10:28:51 pm »
Friends warn friends about possible crotch-sticks, Joynicorns, and face-covering buttons.
« Last Edit: January 25, 2016, 10:31:18 pm by PL1 »
vwalbridge
Re: My new artwork
« Reply #14 on: January 26, 2016, 12:18:20 am »
Scott, that post had me laughing so hard!
 :laugh2:
Dal1980
  • Last login:January 25, 2026, 02:27:53 pm
  • Load "1980"
    • retro.zombiesbyte.com/projects
    • Retro Zombies Byte
Re: My new artwork
« Reply #15 on: January 26, 2016, 08:39:18 am »
Captain America has an additional weapon?
I'm on my last life, best not try anything stupid
-> Check out my other projects at http://retro.zombiesbyte.com/projects
quakebo
Re: My new artwork
« Reply #16 on: January 26, 2016, 03:03:21 pm »
Merquee:
Those are great  they would look great on my blue bartop  here are my measurements for control pannel, side and marquee.  if you do not mind helping me out as I am not that great at doing that sort of stuff  the pac man image I used was not that great quality but all I could find.
And I think simple will look good.
just did this quick but the measurements are correct.  The curve is not right shape but measurement is right size.
Ramakers
Re: My new artwork
« Reply #17 on: January 28, 2016, 12:08:44 pm »
@quakebo: I'll make you the artwork from measurements you gave. Stay tuned.
question: What would you like as title?
« Last Edit: January 28, 2016, 12:41:01 pm by Ramakers »
quakebo
Re: My new artwork
« Reply #18 on: January 28, 2016, 12:48:38 pm »
thank you very much for doing that for me.  I would like multicade as the title please.
Ramakers
Re: My new artwork
« Reply #19 on: January 30, 2016, 07:46:18 am »
Here is a preliminary design:
But we're hijacking this tread so I send you a PM.
quakebo
Re: My new artwork
« Reply #20 on: January 30, 2016, 09:19:50 am »
ok I will have a look at my pm.  also that curve is not the same shape as on my bartop will that matter?  I did send you a pm with a photo of the side of my bartop so you can see the shape of the curve.
« Last Edit: January 30, 2016, 10:44:42 am by quakebo »
bionictoothpick
  • Last login:July 28, 2025, 12:04:08 pm
  • Yes, I still play Maze Craze.
Re: My new artwork
« Reply #21 on: February 19, 2016, 01:13:10 pm »
marquee
I'd like to share your marquee on libretro forum as part of an overlay. Is that ok?
