Author Topic: Using Command.dat in Mame64  (Read 3427 times)
vaderag
  • Last login:May 07, 2025, 11:33:07 am
  • Building my own cab :)
« on: January 20, 2016, 05:11:53 am »
Is there any way to utilise command.dat in Mame64?
I came across this video: and they use MamePlus (i think), but i'm using Mame64 (no-intro / high score) with Hyperspin.... I'd love to get the functionality but at the same time don't want to break my setup!
JamesTKirk
  • Last login:September 29, 2018, 09:09:02 pm
  • Boldly go .....
Re: Using Command.dat in Mame64
« Reply #1 on: January 20, 2016, 10:21:40 am »
I'm not sure Mame64 can do what you want.
The most popular MAME derivatives that support Command.dat include the following:
MAME Plus!
MAME Plus! UI
MAME Plus! eXTended
MAME Plus! Plus Kaillera
MEWUI
M+GUI
ShmupMAME
ShmupMAME UI
ShmupMAME+GUI
I'm running MamePlus! and really like it. If this feature is important (and I can easily see how it would be), you might consider switching to MAME Plus!
« Reply #2 on: January 20, 2016, 10:27:14 am »
I haven't used it, but CP Wizard can also display command.dat info
http://headsoft.com.au/index.php?category=cpwizard&page=about
I believe it can work alongside a front-end.
vaderag
« Reply #3 on: January 20, 2016, 11:29:09 am »
MAME Plus!
MAME Plus! UI
MAME Plus! eXTended
MEWUI
M+GUI
ShmupMAME
ShmupMAME UI
ShmupMAME+GUI
Does Mame Plus work with all the same Roms etc as vanilla mame? Is it also possible to disable nag screens and enable hi score support with it?
vaderag
« Reply #4 on: January 20, 2016, 11:30:19 am »
Oh - that looks really promising... will need to experiment i think (and I'm still in setup phase so maybe that can come later!!)
« Reply #5 on: January 20, 2016, 03:02:29 pm »
I don't know about you, but I'd rather use CP Wizard (accessible through the Pause menu).  I don't want anyone mucking around with the TAB button and screwing up other stuff.
D
vaderag
« Reply #6 on: January 20, 2016, 03:55:09 pm »
D
That does sound better... is there a good guide on setting it up for visibility in pause?
« Reply #7 on: January 20, 2016, 04:14:24 pm »
http://headsoft.com.au/index.php?category=cpwizard&page=install
Seems simple enough.
