Author Topic: Should I use the CGA/EGA input or the VGA input?  (Read 1922 times)
jmcginley
  • Last login:September 22, 2023, 12:23:40 pm
« on: January 13, 2016, 04:08:52 pm »
I'm planning on running GroovyMAME and CRT Emudriver with a Radeon 4xxx series card on my Wells Gardner D9200. It has an input for either CGA/EGA or VGA. In order to run all MAME games as close to their original resolution and refresh rate as possible, which input should I be using?
« Last Edit: January 13, 2016, 04:30:14 pm by jmcginley »
Calamity
  • Moderator
  • Last login:February 19, 2026, 06:15:36 am
  • Quote me with care
Re: Should I use the CGA/EGA input or the VGA input?
« Reply #1 on: January 13, 2016, 05:22:48 pm »
You can only use the VGA as far as I understand.
Steps to create a log:
jmcginley
« Reply #2 on: January 14, 2016, 08:33:25 am »
Thanks, Calamity. I'll make sure I connect through VGA then. I can just connect a VGA cable from my graphics card tot he VGA port on the monitor then? No converters or any other equipment necessary?
DudeRegular
« Reply #3 on: January 14, 2016, 11:34:42 pm »
You should be fine doing that.
