Author Topic: idle return to Mala  (Read 4260 times)
creeksidetech
  • Last login:January 14, 2016, 11:15:47 am
idle return to Mala
« on: January 12, 2016, 11:52:58 pm »
Hi im running mala frontend with mame32ui emulator and have it working great but i need a way so that after a game is played(or given idle time) it returns to the mala frontend.  i know i can hit escape but i want it to do it automaticly.  thanks for any input.
  • Last login:Yesterday at 12:23:29 pm
Re: idle return to Mala
« Reply #1 on: January 13, 2016, 10:41:21 am »
You could have an autohotkey script that kills MAME if none of the controls are touched for a set period of time.
I'm just here to tell you it's possible.
It's up to you to do the research and write the script.
creeksidetech
« Reply #2 on: January 14, 2016, 11:16:16 am »
I used A nice little program(auto hotkey script) that does just that inside windows, works great if pc is idle for 4 minutes it hits the escape key.  But when i open the Mala program it either over powers windows and ignores the command or it goofs with the windows idle counter. I see other emulators have this feature built in but i do Realy like the way I have everything laid out now and hate to have to rebuild just for what is likely a simple fix for someone that Has been doing this longer then me.  Thanks
