Author Topic: 4 ohm speakers on a 60 in 1  (Read 2423 times)
sollyscomputers
  • Last login:March 06, 2019, 01:31:51 am
  • Jukebox? check! Now on to cocktail cab
    • Softweb Developments
« on: January 11, 2016, 11:56:58 pm »
Hi guys,
Can someone tell me if I can connect 2 x 4 ohm speakers on my 60 in 1 jamma board through a small stereo amplifier for arcades
John
behrmr
Re: 4 ohm speakers on a 60 in 1
« Reply #1 on: January 12, 2016, 09:15:06 pm »
If you use the "headphone jack" that should be line out so you can pipe that into your amp.  If you are using the JAMMA audio out pretty sure you need an 8 ohm load so you could wire your speakers in series and not use an amp since the 60-in-1 has an on board amp (power by +12V from your power supply).
sollyscomputers
« Reply #2 on: January 14, 2016, 05:32:16 am »
Thanks,
I'm not using the card's sound, I'm running the sound through a seperate little amp so hopefully it'll be OK
John
