Author Topic: Help me decide my I-Pac Requirements  (Read 1866 times)
ZPaul2Fresh8
  • Last login:February 06, 2020, 03:01:59 pm
« on: January 07, 2016, 07:45:48 pm »
Building a modern 4 player Mame with approximately  51 inputs. Also going with RGB leds as well so I'm calculating 117 outputs needed as well.
I'm guessing I'll need (2) I-Pac Ultimate I/O's. 48 inputs and 96 outputs each.
My questions & concerns are,
1: will they work in conjunction with each other?
2: is there a cheaper alternative than $99 each?
Sent from my SM-N920T using Tapatalk
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
Re: Help me decide my I-Pac Requirements
« Reply #1 on: January 09, 2016, 09:11:48 pm »
I would just use a ipac4 & a led PacLED64 Advanced LED Controller.  It will save you money & less conflicts or use just one ultimate I/0 & buy the wiring for players 3, 4.
I used to have a 4 player cpu, but I rarely had 4 players.  So I did what a lot of mamers did & built a ultimate 2 player
If you need any of these items I am a reseller for Ultimarc & I ship from the US.  My webstore is arcadeemulator.net
thanks
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
paigeoliver
  • Awesome face!
« Reply #2 on: January 09, 2016, 11:10:42 pm »
What are the dimensions on that beast of a panel, I can't quite read the picture.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: January 10, 2016, 07:16:40 am »
For a panel with the number of inputs and outputs you mention, it would need 2 X Ultimate I/O. We have special firmware to set one board to a different ID. Dont forget the price includes all switch wiring and LED power cable.
But another solution for a very large panel, which is also pre-wired like the Ultimate I/O would be to use two x Mini-PAC and two x PacLED64.
The other advantage of that solution is you would be able to mount each of the boards on its own side of the panel thus avoiding any wire-length issues and the standard wiring harness would reach and also the wiring on our RGB LEDs would reach so everything would plug together easily.
