Author Topic: Painting vs Laminate  (Read 1765 times)
Goz
  • KOTA
« on: January 12, 2004, 01:22:58 am »
Ok I'm working on my first MAME cabinet and have gutted, cleaned and added what I need to add. I began painting two days ago and have one side of the cabinet looking beautiful. Unfortunately the other side is jacked. It looks very bad (pits, scratches, etc).
Question:
Anyone have any experience with using a laminate to cover a side?
I found some laminate at Home Depot, but thats about $40 per sheet and figure will need 2 + sheets.
It's not that I'm cheap, but the laminate material look hard to work with.
Any recomendations on other ways to cover the cabinet?
Thanks in advance for any help.
-Goz
nipsmg
  • Last login:Today at 08:18:32 am
  • ROONEY!! ERRGH!!
    • Arcadia
Re:Painting vs Laminate
« Reply #1 on: January 12, 2004, 07:50:44 am »
Vinyl-
The "D" style black 40" vinyl is on sale till 02/29/2004 for $2.18 a foot.
I'm SERIOUSLY thinking about doing this instead of paining it..
But then again, if I do that, the sideart might not look as good..
ARRRGGGHHH!!! DECISIONS!!  ;D
--NipsMG
Lance
  • Last login:December 08, 2008, 10:20:09 am
  • banned
    • arcade.spamrevenge.com
« Reply #2 on: January 12, 2004, 08:59:16 am »
I just spent the weekend stripping, filling, sanding and putting down primer.  If I were to do it again I would probably just go the laminate route.  Paint and paint supplies aren't cheap, and I probably spent close to 40-50% of the cost of laminate.  I think for the extra few dollars it would be worth it to get laminate for the sides.  You'll have a perfectly smooth surface with perfect color.
lance
owlicks
  • Last login:January 20, 2004, 10:18:24 pm
« Reply #3 on: January 20, 2004, 11:00:15 pm »
I'd highly recommend going the laminate route.  It can be a little intimidating if you've never done it, but really it's not very tough at all as long as you have a router handy.  I did my cab all in black laminate and it turned out great.  If you have some odd angles it can be tough pre-cutting laminate to fit around those, but it's worth it.  My cab was my first time doing it and it really was not very hard.  Just make sure to get a straight bit for your router and you'll be set.  I can post some pics of mine if you'd like.
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
« Reply #4 on: January 21, 2004, 01:28:32 am »
^ everything he said.You will be spending a lot of money on the cab anyway so why not do it right ! :)
So go with laminate !
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
« Reply #5 on: January 21, 2004, 11:03:34 am »
Laminate cuts like butter with a router
Goz
  • KOTA
« Reply #6 on: January 21, 2004, 12:39:22 pm »
Thanks for the feedback, Laminate it is.
I may do the front in the vinyl laminate from Happ and the sides, etc in a formica / wilsonart (hard laminate). When I've got it done, I'll snap some pix.
Thanx,
Tailgunner
  • Last login:October 06, 2009, 01:21:16 pm
« Reply #7 on: January 21, 2004, 08:06:05 pm »
Laminate isn't that difficult to do, though you'll need access to a router to trim it once it's in place.
I took a few pics when I covered my Dynamo cab, you can see what's involved here: http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=12414
