Author Topic: ATOM-15 trouble modifying BIOS for HD 7850.  (Read 10135 times)
chrisvg
  • Last login:August 03, 2019, 09:47:50 pm
  • Blast City fanboy!
« on: January 07, 2016, 01:34:47 am »
Apologies for posting multiple threads reporting issues/requesting help, I don't want to come across as annoying!
I'm not sure if ATOM-15 is still actively in development, however I just wanted to report a problem when trying to modify the BIOS for my HD 7850 card.  I imagine this is not so much a bug with ATOM-15, but a compatibility issue.  Not sure if it's something that can be resolved or not, just figured I'd post this in case Calamity want's to have a look.
The ATOM-15 v.1.1 window displays the following information about my dumped BIOS file:
File size: 131072 bytes
Vendor ID: 1002h
Device ID: 6819h
Checksum: 2400h
Int 10h proc: 039Ah
Standard service: 5A7Fh
VESA service: 52F8h
When I select any combination of monitor range options I get the following error: "Hook not possible. Not enough blank space below 0xFFFF."
I've attached a copy of my dumped BIOS file, along with the log files generated by ATOM-15.
  • Last login:March 15, 2026, 04:39:26 pm
Re: ATOM-15 trouble modifying BIOS for HD 7850.
« Reply #1 on: January 07, 2016, 09:55:43 am »
I've modified ATOM-15 to detect blank space as a combination of 00 and FF characters. This version will patch your bios, but I can't guarantee it won't brick your card. Be warned.
chrisvg
« Reply #2 on: January 08, 2016, 03:57:46 am »
That did the trick!
I successfully created a modified BIOS file and then used a USB DOS boot disk to test the modified BIOS with the lbios and z tools.. no problems there, so went to use atiflash to flash the BIOS and it hung ... I then left it alone for 10 minutes .. still no progress.. oh no!
I then decided to reboot and fortunately it looks like the DOS atiflash tool did nothing for some reason or another.
So, I boot back into Windows and use the Windows version of the ATIFlash utility and it successfully flashed the modified BIOS .. reboot..
Success!  :cheers:
So, thanks for all of your efforts mate! Check your PayPal account coz the beers are on me this weekend :)
« Last Edit: January 08, 2016, 04:02:22 am by chrisvg »
« Reply #3 on: January 08, 2016, 04:58:33 am »
Thanks chrisvg, I appreciate that you took the risk, now we know that ATOM-15 works on the 7800 series too, I'll bump the version with this new patch. Maybe the DOS Atiflash can't handle the newer chipsets properly.
I believe I had read there was an issue with bios signature requirements starting from the 7000 series, it looks like it worked after all.
Cheers.
Andypc
  • Last login:November 18, 2024, 01:45:58 pm
« Reply #4 on: July 30, 2016, 01:42:17 pm »
I have a similar issue. I have just bought 3 Sapphire HD 7750 Low Profile cards for my arcade machines. I successfully flashed a Sapphire HD6670 so though these would be fine. I first got the error: "Hook not possible. Not enough blank space below 0xFFFF."
The ATOM-15 window displays the following information about my dumped BIOS file:
Vendor ID: 1002h
Device ID: 683Fh
Checksum: EF00h
Int 10h proc: 03A6h
Standard service: 5B0Dh
VESA service: 5386h
So I tried the modified ATOM-15 from this thread and it appeared to patch the bios rom ok. The issue is that when I use ATIWinFlash to program the bios-mod.rom back to the card, I get the error message "Vbios image not found"
Any help would be appreciated as I have three of these cards I need to mod.
Dalba
  • Last login:August 18, 2025, 02:54:37 pm
« Reply #5 on: August 06, 2016, 01:59:57 pm »
I have a VTX 7850 and i encounter the exact same issue as you. I can save my bios with atiflash, patch bios with modified atom15 of this topic, but i get the error message "Vbios image not found" when trying to flash...
I use what seems to be the latest version, atiflash 274... I wonder what version was used by chrisvg...
Dalba
« Reply #6 on: August 30, 2016, 12:38:21 pm »
I hope Calamity will read this as i don't want to create another topic for this. I encounter the exact same issue as original poster above with an Asus 7750, even with the modified version of atom 15 you posted above.
Whatever settings i try, i get this :
I join my bios dump and txt files if it can help...
« Last Edit: August 30, 2016, 12:40:04 pm by Dalba »
R-Typer
  • Last login:September 09, 2024, 12:50:41 pm
  • C64 Rulez!!!!
« Reply #7 on: August 30, 2016, 01:53:04 pm »
I used previous unpatched version of ATOM and it patched my MSI 7770 and ASUS 7850 without any issues. I guess I was just lucky to not have issues with these two cards I have.
« Last Edit: August 30, 2016, 01:54:52 pm by R-Typer »
« Reply #8 on: September 04, 2016, 09:28:15 am »
ATOM-15 v1.2
- v1.2 - September 2016
    - Detect blank space as a combination of 0x00 and 0xFF characters.
    - Reduce by 256 bytes the size required by the BIOS hook, now only 572 bytes of blank
      space are needed to patch the BIOS.
    - Fixed bug that caused wrong checksum correction in some cases.
This version should fix the "Vbios image not found" issue with ATIWinFlash. It includes the feature for better detecting blank space that was present in the test build I had attached some posts above. It also needs less blank space now, so it should patch some cards where previously it couldn't find enough space.
(It won't patch Dalba's last posted BIOS, however. That one could be patched by editing it first with an hex editor, if he wants to take the risk).
Dalba
« Reply #9 on: September 04, 2016, 11:41:03 am »
I'm OK to take the risk as i only spent a few bucks on this card, but i must admit i don't now where to start and what to do...
« Reply #10 on: September 05, 2016, 12:45:01 pm »
Try this one, make sure you know beforehand how to fix it in case it ends up bricked.
Dalba
« Reply #11 on: September 06, 2016, 07:07:46 am »
Really thanks ! I will try ASAP and make a report.
Andypc
« Reply #12 on: September 18, 2016, 04:59:45 pm »
 :applaud: Huge Thanks Calamity 1.2 did the trick perfectly.  :cheers:
Dalba
« Reply #13 on: September 29, 2016, 02:53:42 pm »
Hello, i tried to patch your modded 7750 bios with latest atom15 but i can't as i get an error.
But i was wondering : did you create this bios in order to be able to patch it with atom15 ? Or is it an already patched bios ?
« Reply #14 on: September 29, 2016, 03:18:28 pm »
What error are you getting?
Anyway, that's an already patched BIOS, I used a modified version of Atom-15 to manually patch it.
Dalba
« Reply #15 on: September 30, 2016, 04:25:10 am »
Here's a screen of the error :
What i would like is being able to patch card to use either only 15khz, either only 31khz, depending the cab i will use card for...
« Reply #16 on: September 30, 2016, 05:14:56 am »
I had already patched that bios, it can't be patched twice.
You need a modified version of ATOM-15 to do that. It'd be nice to know if a bios patched like that works at all (the one I posted), before I consider releasing a new version of ATOM with support for manual patching (dangerous).
Dalba
« Reply #17 on: October 07, 2016, 02:13:04 pm »
Hello,
I finally had time to test seriously my hd7750 with your modified bios in my blast city. I can tell you it works wonderfully !
I would have a request... Could you please send me a new modified bios for my hd7750 that would support only 15khz during boot ? I then could test it in a 15khz Astro city !
« Last Edit: October 08, 2016, 06:08:46 am by Dalba »
Dalba
« Reply #18 on: November 16, 2016, 03:13:08 pm »
Hello,
Little Up in case Calamity stop by this topic  :P
