Author Topic: Ultrastik 360 shafts  (Read 1579 times)
baldgeek
  • Last login:July 25, 2021, 03:38:21 am
« on: January 05, 2016, 12:02:22 pm »
What shafts fit the U360?  Also, are they bat tops longer than the ball top, I bought 2 ball tops and i'm bottom mounting them and would like the shaft to be higher out of the top of the CP. Routing the CP is not an option since I already installed threaded inserts into the wood. Are bat and ball tops interchangeable or are you stuck with one once you ordered it.
btw.. not sure if this should be main, or woodworking. not really planning on modifying the wood anymore
haynor666
  • retro maniac
Re: Ultrastik 360 shafts
« Reply #1 on: January 05, 2016, 01:42:41 pm »
baldgeek
« Reply #2 on: January 05, 2016, 02:34:31 pm »
LJW? Couldn't find them. Did you mean JLW?
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: January 05, 2016, 02:55:10 pm »
Yes.
haynor666
  • retro maniac
« Reply #4 on: January 05, 2016, 03:55:16 pm »
Yes, my mistake.
