Author Topic: Updating from .160 to .169 incl Drivers  (Read 7719 times)
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« on: January 03, 2016, 06:45:34 am »
I'm going to start this thread to keep it all in one spot and to help anyone else who needs to update from older GM etc to new.
I started by just putting the new mame.exe into the folder and switching to d3d9ex, running it to see how it would go, and it worked to a degree, but some games didn't work at all, others ran way too fast.
So I created a new mame.ini and made the appropriate adjustments for my monitor etc, and pretty much everything seems ok now as far as the few games i tested..
EXCEPT for mame run from cmd (no game). I get a really fast scrolling picture like it's out of sync. How do i fix this? (log attached)
Older mame would display on screen perfectly.
But.. what about the new drivers etc, how do i setup VMM now with my custom monitors preset?
Like i've done with vmm.ini and monitor.ini ? Is that all?
« Last Edit: January 04, 2016, 02:53:57 am by Sledge »
  • Last login:Today at 05:35:07 pm
Re: Updating from .160 to .169
« Reply #1 on: January 03, 2016, 07:11:22 am »
VMMaker 2.0 is configured through the settings dialog, instead of vmm.ini. You need to create the moddrss with vmmaker 2.0 in order to use gm 169
Sledge
« Reply #2 on: January 03, 2016, 07:17:02 am »
Ok, will look at that tomorrow...
moddrss ??
« Reply #3 on: January 03, 2016, 07:35:33 am »
Haha I meant modes, sorry, writting from a phone.
Sledge
« Reply #4 on: January 04, 2016, 12:28:25 am »
Ok, I've updated the drivers, and used VMM to create the modes (ms9-29 15Khz only) and installed them, however when i switch to a 15Khz mode I get this:
I've tried adjusting the H.H.15 pot to adjust the horizontal hold, but nothing changes for the better as far as i can see..
Any ideas?
« Last Edit: January 04, 2016, 12:44:41 am by Sledge »
Sledge
Re: Updating from .160 to .169 incl Drivers
« Reply #5 on: January 04, 2016, 03:39:08 am »
I un-installed the drivers, and reinstalled the old ones again, but the same things happen now as before..
Before i run VMM i can't get the correct resolution to stick, but i persevere and run the new VMM, and it displays as above..
« Reply #6 on: January 04, 2016, 04:33:23 am »
Ok, I see, so you mean with the old drivers you still get the bad vertical sync in the picture. Is your card flashed with ATOM-15?
Sledge
« Reply #7 on: January 04, 2016, 04:41:08 am »
yes and yes
was working fine before update..
« Reply #8 on: January 04, 2016, 04:47:15 am »
yes and yes
I've experienced weird behaviour when installing the drivers over a flashed card. It's much smoother to install drivers with the original bios, then flash it back with ATOM-15.
« Last Edit: January 04, 2016, 04:51:50 am by Calamity »
Sledge
« Reply #9 on: January 04, 2016, 04:51:35 am »
yes and yes
I've experienced weird behaviour when installing the drivers over a flashed card. It's much smoother to install drivers with the original bios, the flash it back with ATOM-15.
ok i'll update when i can with how it went :)
Sledge
« Reply #10 on: January 04, 2016, 07:04:23 am »
ok, i uninstalled the drivers through windows (ticking the remove files box), and flashed the card back to standard, installed new drivers and the same thing happens again..
Still get the rolling picture above..
« Reply #11 on: January 04, 2016, 04:43:07 pm »
The only thing I can think of right now is to try this:
http://forum.arcadecontrols.com/index.php/topic,148919.msg1552995.html#msg1552995
Sledge
« Reply #12 on: January 04, 2016, 05:17:15 pm »
Would it be an issue of the previous driver not being removed properly? Is the windows uninstall feature good enough?
« Reply #13 on: January 04, 2016, 05:23:03 pm »
It would be an issue indeed. In my experience the driver management in 7 is pretty good, at least much better than in XP. Double check which version is actually installed, in the device manager. It could be 2.0 has stuck.
Sledge
« Reply #14 on: January 04, 2016, 05:48:42 pm »
As far as i could tell the driver is changing as i un-install etc, but would there be remnants left that could interfere? Or would removing them be truly removing all of it?
« Reply #15 on: January 04, 2016, 05:55:00 pm »
Yeah they get removed properly, no remnants in my experience. The thing that does happens is the os replacing your drivers with another version it has available if it feels like, without notification.
btw the pictures you posted... it's not h-hold but v-hold what could be wrong.
« Last Edit: January 04, 2016, 05:56:50 pm by Calamity »
« Reply #16 on: January 04, 2016, 06:19:56 pm »
Do you get the sync back if you use VMMaker 1.4b? (despite the mode not sticking).
Sledge
« Reply #17 on: January 04, 2016, 06:46:13 pm »
Yeah pretty sure it was installing the MS WDDM drivers 1.1 (or whatever they're called)
I don't think there's a v-hold adjustment pot on a MS9-29??
I'll let you know in a few days when i get back...
« Reply #18 on: January 04, 2016, 06:49:31 pm »
Anyway, you run VMMaker 2.0 all the time, even when reinstalled the old drivers, didn't you?
Sledge
« Reply #19 on: January 04, 2016, 06:51:55 pm »
Yes that is correct
I wish i could keep going with it today, but time is short for 2 days :(
« Reply #20 on: January 04, 2016, 06:56:48 pm »
That's fine, hopefully I'll have a fix by the time you're back.
Sledge
« Reply #21 on: January 04, 2016, 07:27:05 pm »
Thanks mate..
You really opened up a can of worms with all this new stuff ;)
But we appreciate your hard work!
« Reply #22 on: January 04, 2016, 07:30:04 pm »
Too many new things at the same time, never a good idea  ;)
Sledge
« Reply #23 on: January 07, 2016, 06:53:39 am »
Well no matter what i try i can't get it stable now...
Old drivers, old tools,(windows working mostly) old mame.. out of sync
New Tools, new mame... out of sync
Old drivers, new tools out of sync..
Might see if i've got an older image i can put on to get things back up and running, or might start from scratch :(
« Reply #24 on: January 07, 2016, 07:15:08 am »
Are you testing beta 4?
Also, you may want to check this guide: http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=298
« Last Edit: January 07, 2016, 07:18:11 am by Calamity »
Sledge
« Reply #25 on: January 07, 2016, 07:29:36 am »
Yep Beta 4, and followed that guide during the first test as well..
« Reply #26 on: January 07, 2016, 07:38:21 am »
That's so strange. At least you should get sync using the old drivers & old tools, it makes me think something else is wrong.
If you decide to follow the guide starting from scratch, please let me know at what step thigs get bad.
« Last Edit: January 07, 2016, 07:40:33 am by Calamity »
Sledge
« Reply #27 on: January 07, 2016, 07:41:54 am »
Will do.
With GM.169 with old drivers/tools should we be using d3d9ex? or stick with ddraw?
Also, i'm using standard resolutions, not super resolutions, so didn't do that part of the guide..
« Last Edit: January 07, 2016, 07:44:34 am by Sledge »
« Reply #28 on: January 07, 2016, 07:55:09 am »
Will do.
- Old drivers/old tools -> GM 168
- New drivers/new tools -> GM 169
Don't mix them.
Neither d3d9ex nor ddraw. Always use d3d by default until things are up and running.
« Reply #29 on: January 07, 2016, 07:56:52 am »
Besides make sure to grab GM 169 fix 3.
Jonny G
  • Last login:March 04, 2024, 05:59:46 pm
« Reply #30 on: January 07, 2016, 08:01:48 am »
Hi Calamity, just to clarify, we should have D3D set in mame.ini rather than AUTO?
« Reply #31 on: January 07, 2016, 08:04:35 am »
auto = d3d
Jonny G
« Reply #32 on: January 07, 2016, 08:19:13 am »
Thanks for that, you learn something every day.
Sledge
« Reply #33 on: January 07, 2016, 07:05:55 pm »
My mistake sorry, grabbed that, booted in safe mode, removed drivers (to get a stable picture on LCD lol)
Started over, but installing new drivers, ran VMM, (did a little test here and didn't follow your guide, just set it to the correct res (LCD seems to be able to display 640x480 15Khz) and shut down.
Rebooted with CRT connected, and all was good!
Tried (fix 3) Mame with d3d (frame delay on i think), and all good there too so far.
So now i can switch to d3d9ex with frame delay off?
« Last Edit: January 07, 2016, 07:09:55 pm by Sledge »
« Reply #34 on: January 07, 2016, 07:12:49 pm »
Sure.
It was a relief to hear that  ;)
