Author Topic: J-PAC: Problem with P1 Button 5  (Read 763 times)
adrianomartins
  • Last login:January 12, 2025, 07:10:17 pm
« on: January 01, 2016, 03:45:20 pm »
Hi,
I have bought a J-PAC and connected it with the JAMMA harness and PC.
Everything works fine except P1 Button 5.
I checked everything (wire, button, switch, ohmmeter etc.) but it still does not work.
Even shorting the contact on the screw terminal (1SW5) directly does not work, i.e. the button 5 (assigned to Z) on WinIPAC Interactive Panel Designer does not light up.
But if I press button Z directly on the keybard, the button 5 on WinIPAC Interactive Panel Designer lights up
Therefore the problem seems to be directly on the J-PAC near the screw terminal.
Could the J-PAC be faulty?
Where does the track from screw 1SW5 go to?
Are there schematics from the J-PAC?
Thanks a lot and regards
« Last Edit: January 01, 2016, 04:14:58 pm by adrianomartins »
