Author Topic: VMMaker 2.0 refuses to make lower resolutions than 192p  (Read 2282 times)
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
« on: January 01, 2016, 03:12:17 pm »
New VMMaker refuses to make resolution 240x160 (needed for VBA-M to avoid stretching) even I've set correctly desired Ymin in both fields. I'm trying to generate this resolution from user_modes.ini. When I used previous VMMaker 240x160 was created. Am I doing something wrong?
  • Online Online
  • Last login:Today at 01:33:29 am
Re: VMMaker 2.0 refuses to make lower resolutions than 192p
« Reply #1 on: January 01, 2016, 03:17:41 pm »
Edit the monitor presets file and set the progressive lines min value for the preset you're using to 160.
haynor666
  • retro maniac
« Reply #2 on: January 01, 2016, 03:30:11 pm »
Ups, I totally forgot about this. Previosly I always edit this setting in VMMaker.ini. My fault, thanks Calamity :)
