Author Topic: 2xU360 with hyperspin  (Read 2984 times)
fablog
  • Last login:October 11, 2025, 09:46:57 pm
« on: December 29, 2015, 05:15:23 pm »
Hours (days?) trying to configure 2 joystick and I failed :(
Could you direct me to a tutorial to configure 2 U360 with Hyperspin/Rocketlauncher/Xpadder and Mame?
Right now I see my 2 U360 and the UIO in Windows 10 but can't control the menu/game in Mame64 0.168. Xpadder recognize the 2 joysticks.
Thanks.
« Last Edit: December 29, 2015, 05:17:08 pm by fablog »
MydknyteStyrm
  • Last login:March 20, 2024, 12:19:41 pm
  • Makeup FX Gamer
Re: 2xU360 with hyperspin
« Reply #1 on: January 06, 2016, 05:04:34 pm »
Hyperspin doesnt work well with joysticks as of yet. You need to configure Hyperspin through HyperHQ to use the Keyboard, and match those keys in Xpadder. Also, you can have Xpadder start up either when HS starts, or when Windows starts. I have a Hyperspin profile set to load when Windows starts, so that way when you start HS, Xpadder is already in effect. Hope that helps!
EMDB
  • Project RetroCade
« Reply #2 on: January 06, 2016, 06:10:52 pm »
Or even better connect the U360 using the additional harness to a keyboard encoder so it will generate keyboard stokes natively...
MydknyteStyrm
  • Makeup FX Gamer
« Reply #3 on: January 06, 2016, 06:13:04 pm »
But then would you lose the programability of the U360? I have mine in through USB, and can program the controller for different game setups
EMDB
  • Project RetroCade
« Reply #4 on: January 07, 2016, 01:02:17 am »
No. Just connect both: USB for the programming and the harness for the keystokes. Works perfectly fine in my cabinet...
fablog
« Reply #5 on: January 07, 2016, 08:19:31 pm »
Thanks guys  very helpfull. I'll try the additional harness.
MydknyteStyrm
  • Makeup FX Gamer
« Reply #6 on: January 07, 2016, 08:20:34 pm »
If that's right you saved me a ton of xpadder work! Can't wait to try it
