Author Topic: G20-100-003 Megatouch 06/95  (Read 1382 times)
Porsch964
  • Last login:January 18, 2016, 07:55:53 pm
« on: December 28, 2015, 01:04:59 pm »
Help - my megatouch ( Tournament edition) is having problems
Originally - it was flashing Start up Normal (blue screen)
I fixed the fan, it was filled with dust and debris - machine went back to normal operation.
After playing the game or games for 10 minutes - the issue of "monitor is normal" is reposting up again. :banghead:
Should i pull the board and re-seat each CHIP and do a better job of cleaning ?
The fan is now working and has no stopped.
Thoughts of the next repair approach.   My friend thought it would be a hard drive , but i don't think this model has a hard drive.
I believe my edition is mostly firmware versus his later edition with a harddrive.
thanks for anyhelp.
jpc
« Last Edit: December 28, 2015, 01:09:21 pm by Porsch964 »
Porsch964
Re: G20-100-003 Megatouch 06/95
« Reply #1 on: January 08, 2016, 10:56:18 am »
Bmp before pulling out everything for a EPROM cleaning and reseat
paigeoliver
  • Awesome face!
« Reply #2 on: January 09, 2016, 11:25:44 pm »
You need to check your voltages. IIRC those megatouch used a PC style power supply and yours is now over 20 years old.
Porsch964
« Reply #3 on: January 18, 2016, 07:50:45 pm »
The power supply was exchanged with a more current one.
I'll verify the voltage to ensure its correct - thanks
« Last Edit: January 18, 2016, 07:56:01 pm by Porsch964 »
