Author Topic: win 7 triple screen dual 4890's  (Read 1839 times)
gurbzs
  • Last login:August 09, 2024, 07:38:29 am
  • Creamy arcade graphics
« on: December 19, 2015, 05:45:37 am »
Hi Groovy gamers,
I've updated my rig since last year (just4fun buggy boy thread), using now a asus maximus ii formula mono with 2 ati 4890's.
Can't seem to get more screens than 2, whatever I do. (tried donotdetectdisplay regedit)
The two graphic cards have 4 DVI outputs together and win 7 shows all 4 outputs.
I just can not select them: maybe output 1 and 2, 1 and 3 but Not 1,2 AND 3.
Any ideas how to solve this?
Is a 3 screen setup even possible with win 7?
Best regards,
Gurbz
gurbzs
Re: win 7 triple screen dual 4890's
« Reply #1 on: December 19, 2015, 03:37:19 pm »
Allright, made some progress after another tweak.
Used donotdetectdisplay regedit on the other card and I have now three displays.
Still one problem, see the log file.
GM won't start the menu, can't initialise DDraw, etc, unable to create window.
How do I fix this?
  • Last login:Today at 08:11:58 am
« Reply #2 on: December 19, 2015, 04:58:53 pm »
Try forcing -video d3d from command line.
gurbzs
« Reply #3 on: December 19, 2015, 05:05:47 pm »
Yeah, it works from the command line, buggy boy runs on triple screen.
Is it the User Interface setting, the game list that triggers this?
« Reply #4 on: December 21, 2015, 05:58:26 am »
The problem is, there is an issue with W7 and interlaced modes that makes them ran at half their speed, so GM by default selects -video ddraw when an interlaced mode is used. But the funny thing is there's a second bug related to DDraw and W7 mode switching*. This second bug is normally bypassed by Switchres, but Switchres is not applied to secondary displays, so...  By forcing -video d3d from command line you prevent GM to fall back to DDraw, and thus bypass the bug.
You may force -d3d by creating a specific ini for that game and adding -video d3d in it.
Then, you may bypass d3d running at half speed by using -frame_delay.
* This bug is W7's, not GM's-
