Author Topic: Bally Midway games running fast  (Read 2801 times)
timply
  • Last login:November 17, 2018, 02:18:22 am
« on: December 13, 2015, 07:07:36 pm »
Games like Tapper, Timber and Journey are running at around 200% and was wondering if anybody has encountered this problem before?
Windows 7
GM 0.168 w/ Super Resolutions
Kortek KT-2914F
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
Re: Bally Midway games running fast
« Reply #1 on: December 14, 2015, 05:13:31 am »
Those games are working at 30 Hz so probably forced those to work at 60 Hz by using syncrefresh 1 and using progressive resolutions. Is Kortek KT-2914F a tri-sync monitor ?
In windows 7 every interlaced resolution in presented at half of actual refresh rate and if You are force syncrefresh and use interlaced resolution actual gameplay should be still 100%.
timply
« Reply #2 on: December 14, 2015, 04:59:23 pm »
Setting the syncrefresh to 0 fixed it! Thanks!
Should I make syncrefresh 0 the default setting or just for those games?
haynor666
  • retro maniac
« Reply #3 on: December 15, 2015, 09:11:44 am »
By default should be 0. Groovymame will change this option if required.
