Author Topic: Help with Sega jvs type 1  (Read 1321 times)
jkl
  • Last login:March 13, 2020, 10:01:58 am
« on: December 11, 2015, 02:26:34 pm »
Hi I can't figure out my problem...
I have 2x sega jvs type 1 i/o.
Both turn on, are recognized by naomi board that reads fw version and other data, but I can't get any key to work even in input test.
Wired a db15 port following ags pinout (joystick leds are turning on too)...
Powered with 5v AND 12v, even if I guess that without lamp out 12v are useless.
Used 2 different usb cables.
Same Naomi work flawlessy with jvs 2 jamma.
jkl
Re: Help with Sega jvs type 1
« Reply #1 on: December 12, 2015, 02:42:01 pm »
SOLVED.  :applaud:
Just for future reference: a ninja-guy called Mitsurugi-w, who have is own arcade forum (don't know if I can publish the link here), gave me the solution: pins 1 and 3 of 60-pin digital connector need to be shorted.
After this all of the inputs become fully functional.
If they aren't linked no one of the 60 pins is detected.
