Author Topic: What snes emu to use for a vertical cab?  (Read 4401 times)
ivwshane
    • My first mame cab! (WIP)
« on: December 10, 2015, 07:42:44 pm »
I have a vertical cab and I'm trying to figure out how to get snes working on it. I've tried both snes9x and znes but neither seem to have a screen rotation option.
Any help?
ivwshane
Re: What snes emu to use for a vertical cab?
« Reply #1 on: December 17, 2015, 02:45:15 pm »
I just decided to redo the layout and rotate windows instead of having mala and mame auto rotate. Now I just need to figure out how to configure a snes emulator to look right.
vwalbridge
« Reply #2 on: December 17, 2015, 02:48:44 pm »
Sound like you already figured out your own problem but if not, check out RetroArch.
It's the only Emulator front end out there that I know of that lets you rotate a NES/SNES screen 90 degrees.
ivwshane
« Reply #3 on: December 17, 2015, 04:37:25 pm »
Is it available on windows? I've only used it on pi installations and it wasn't the easiest thing to use.
I didn't solve my problem but I did find a solution. I've decided to run windows in portrait mode and I simply recreated my layout to fit.
vwalbridge
« Reply #4 on: December 17, 2015, 05:17:35 pm »
yes, retroarch works on Windows.
You can learn how to set it up here:
http://forum.arcadecontrols.com/index.php/topic,148525.0.html
