Author Topic: Player 1 and Player 2 both buttons coming up 2 when pressed?  (Read 1705 times)
R0CK632
  • Last login:December 11, 2015, 09:56:12 am
« on: December 07, 2015, 04:53:54 pm »
Just set up my first control panel and wired everything and when i goto setup emulators both player 1 and player 2 are both coming up and set to the 2 key.  Im using the xarcade encoder.  Each button has a different color wire going to the encoder so its not hooked up to the same button.  Any thoughts or is this how it works?
Yenome
  • Last login:November 14, 2025, 04:36:28 am
  • Punch a fish. Make a wish
Re: Player 1 and Player 2 both buttons coming up 2 when pressed?
« Reply #1 on: December 07, 2015, 05:21:51 pm »
i would say check to make sure you dont have one of the buttons connected to the (NO) on the microswitch or never opened which means it never stops sending a signal unless it is pressed and held down. also pics of the wiring at the buttons and the encoder may help a lil too.
  • Last login:Today at 04:49:10 am
« Reply #2 on: December 07, 2015, 05:43:17 pm »
I'm assuming that you have already tried using the P1/P2 Start buttons to "type" in Notepad and both are sending "2" instead of sending "1" and "2" -- if not, please check that before doing aything else.
Next check that the wires are on the NO and COM tabs, but not the NC tab.
My first thought was that the X-arcade encoder uses isolated grounds (one per connector), but the P1 Start button (J2 purple wire) and the P2 Start button (J2 green wire) both use the same ground (J2 grey wire) per the diagram here.
With power removed, use your multimeter to check for a short between the J2 purple wire and J2 green wire.
vwalbridge
« Reply #3 on: December 07, 2015, 05:46:11 pm »
It actually stands for "Normally Open"
NO = Normally Open
NC = Normally Closed
R0CK632
« Reply #4 on: December 07, 2015, 07:34:33 pm »
Figured it out, it was the mode switch it comes with.. it needed to be in mode 1. Thanks for the help
Yenome
« Reply #5 on: December 08, 2015, 10:59:15 pm »
NO = Normally Open
I knew i was gonna get it wrong lol.
