Author Topic: Where on Earth is the Power Switch wires on Dell Xps 420  (Read 2078 times)
R0CK632
  • Last login:December 11, 2015, 09:56:12 am
« on: December 04, 2015, 06:14:33 pm »
Trying to find the power switch wires so I can make an external power button.. The switch is located in the front right behind that open area on the left side of the pic.. Any help again  would be greatly appreciated.  Thanks fellas
« Last Edit: December 04, 2015, 06:16:27 pm by R0CK632 »
big10p
  • Mmmm, arcade classics!
Re: Where on Earth is the Power Switch wires on Dell Xps 420
« Reply #1 on: December 04, 2015, 06:29:28 pm »
There's usually a header on the mobo where the power button (amongst other things) connects. Something like in this pic. Can't really see in your photo. What does the gray wire with black ends connect to?
05SRT4
  • Check out my Pow Pow
« Reply #2 on: December 04, 2015, 06:36:49 pm »
Its most likely the grey wire with the black ends.
Worst case you can add a switch the the actual power button its self. Just take the front panel off. Check the solder points on the back of the power button panel.
mgb
  • North East, US
« Reply #3 on: December 04, 2015, 08:49:25 pm »
That header that was mentioned is usually on one corner of the motherboard.
You're gonna have to get in there and move some crap around to find it.
You can simply take apart the front switch/panel and get to the cable.
If you know where the switch is, you know where the cable is
