December 02, 2025, 03:15:20 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Video Games
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Front End Support
Maximus Arcade
(Moderators:
nickynooch
MA cut off screen
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: MA cut off screen (Read 5997 times)
Hiren
Trade Count:
0
Jr. Member
Offline
Last login:January 11, 2016, 02:19:38 pm
I want to build my own arcade controls!
MA cut off screen
on:
December 01, 2015, 09:26:35 am »
Hi, i have this problem from the first time i booted MA up and it's this fix position. It has nothing to do with this monitor. Everything outside of MA work perfect, is there anyway to fix this? After four days of trying to figure it out. I'm stumped, and not the most literate when it comes to technical jargon. Thanks.
Last Edit: December 02, 2015, 12:35:13 am by Hiren
Logged
thomas_surles
Trade Count:
+1
Full Member
Offline
Last login:September 13, 2024, 06:34:49 pm
Re: MA cut off screen
Reply #1 on:
December 01, 2015, 11:15:49 pm »
change the resolution
Logged
Ball Buster
http://forum.arcadecontrols.com/index.php/topic,151488.0.html
Galaga Tully
http://newforum.arcadecontrols.com/index.php/topic,159736.0.html
Ghouls 'N Ghosts Tully
http://forum.arcadecontrols.com/index.php/topic,164624.0.html
Yenome
Trade Count:
0
Full Member
Offline
Last login:November 14, 2025, 04:36:28 am
Punch a fish. Make a wish
Reply #2 on:
December 02, 2015, 12:37:26 am »
agree need to change the resolution in MA. CTRL-P while it is running will get you into the preferences.
Logged
Hiren
Trade Count:
0
Jr. Member
Offline
Reply #3 on:
December 02, 2015, 12:51:02 am »
I have done that, and while its the optimal way right now. It makes it small and still off center.
Last Edit: December 02, 2015, 12:52:48 am by Hiren
Logged
Yenome
Trade Count:
0
Full Member
Offline
Reply #4 on:
December 02, 2015, 02:50:50 am »
what resolution are you running on your desktop and in MA
Logged
Hiren
Trade Count:
0
Jr. Member
Offline
Reply #5 on:
December 02, 2015, 03:39:28 am »
I switched from 1920x1080 to 1280x1024
Logged
Yenome
Trade Count:
0
Full Member
Offline
Reply #6 on:
December 02, 2015, 12:57:34 pm »
so both MA and your desktop resolution are now 1280x1024?
Logged
Hiren
Trade Count:
0
Jr. Member
Offline
Reply #7 on:
December 02, 2015, 01:24:59 pm »
nope, just Maximus. When i select 1280x1024 on my monitor and start Maximus, it bleeds on to my second screen. I know what you're thinking, unplug the second monitor. Normally I would, but eventually it's going to be on a living room tv.
Last Edit: December 02, 2015, 02:00:11 pm by Hiren
Logged
Yenome
Trade Count:
0
Full Member
Offline
Reply #8 on:
December 02, 2015, 04:04:53 pm »
how are the monitors setup. it almost sounds like you have an extended desktop which would cause MA to not look right if both monitors have diff resolutions. course you could always just disconnect one for now just to test it. I'm still lost on why there is two hooked up if you will be later putting on an HDTV that would handle the 1080p resolution just fine.
Logged
Hiren
Trade Count:
0
Jr. Member
Offline
Reply #9 on:
December 02, 2015, 09:56:10 pm »
side by side monitor setup, main monitor 1920x1080 and the second monitor is to the right 1680x1050. With the setup right now, it saves me going back and forth, in case something crashes or I need to add an Emu, rom, theme, etc.
Logged
Yenome
Trade Count:
0
Full Member
Offline
Reply #10 on:
December 03, 2015, 01:46:34 pm »
well depending on how its setup in windows i think the two monitor setup might be whats causing your issues with MA being off center. i have been unable to recreate your issue. even with the monitors set diff i still have no issue like your self. it almost doesnt sound like an issue with MA but with the setup and how its handling the two monitors. I would say unplug the second screen start MA and see if it goes to normal if it still is off center then we know it maybe with MA
Logged
Hiren
Trade Count:
0
Jr. Member
Offline
Reply #11 on:
December 04, 2015, 01:31:50 am »
Yep, that did it. Maximus does not like my dual monitor set up. thanks for the help.
Logged
Yenome
Trade Count:
0
Full Member
Offline
Reply #12 on:
December 04, 2015, 02:07:16 pm »
in order to get the same issue i had to make two monitors work as one in an eyefinity display instead of extended desktop. so you might be able to play with how they setup to get it to work. what video card you using?
Logged
Hiren
Trade Count:
0
Jr. Member
Offline
Reply #13 on:
December 05, 2015, 03:03:52 am »
a single gtx 690
Last Edit: December 05, 2015, 03:05:41 am by Hiren
Logged
Yenome
Trade Count:
0
Full Member
Offline
Reply #14 on:
December 07, 2015, 04:11:51 pm »
I dont think it would be but it could be defaulting to use the two monitors as one big screen.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Front End Support
Maximus Arcade
(Moderators:
nickynooch
MA cut off screen
