Author Topic: Notebook Computer inside Full-size Mame Cabinet  (Read 5744 times)
R0CK632
  • Last login:December 11, 2015, 09:56:12 am
« on: November 20, 2015, 11:38:32 pm »
Is there anything wrong using my old Notebook computer to run inside my new full-size mame cabinet. I already have all the roms and hyper spin setup on it already. Don't feel like transfering everything over to a tower.. Thanks
TapeWormInYourGut
  • Last login:Today at 12:03:16 am
Re: Notebook Computer inside Full-size Mame Cabinet
« Reply #1 on: November 21, 2015, 09:54:51 pm »
Not particularly.
« Reply #2 on: November 22, 2015, 12:48:44 am »
Nothing wrong at all unless you plan to use its screen too..
05SRT4
  • Check out my Pow Pow
« Reply #3 on: November 22, 2015, 01:05:55 am »
^^^^ +1
vwalbridge
« Reply #4 on: November 22, 2015, 01:25:06 am »
My only concern with laptops inside cabs is how to power them on from the outside of the cab.
dkssprs
  • Last login:February 23, 2023, 01:32:26 pm
    • Bub & Bob's BARTOP
« Reply #5 on: November 22, 2015, 12:50:46 pm »
+1
I think that thats the only problem with laptops.
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« Reply #6 on: November 22, 2015, 06:25:20 pm »
How would you get a 15khz signal from a laptop?
Yenome
  • Last login:November 14, 2025, 04:36:28 am
  • Punch a fish. Make a wish
« Reply #7 on: November 23, 2015, 02:21:31 am »
i would say in this case best to plug it into a power strip and run the power strip cord outside the cabinet.
« Reply #8 on: November 23, 2015, 09:47:04 am »
+1 that's would I would do.
R0CK632
« Reply #9 on: November 24, 2015, 10:18:03 am »
Heres my solution. I tapped into the power switch on my laptop and now i can run a momentary switch to anywhere I want in the cabinet.  Just worried about the laptop overheating in the cabinet.  I am going to purchase a cooling pad for it to run as well.
spystyle
  • Thanks alot, now I have to build a time machine and warn myself yesterday!
  • Last login:February 23, 2021, 02:30:18 pm
« Reply #10 on: January 04, 2016, 01:20:02 pm »
The laptop's power button should be a typical momentary switch with two solder points, I think you could solder wires from those two solder points to a momentary switch mounted on the outside of the cabinet.
kooky
  • Last login:June 22, 2025, 01:21:45 pm
  • My Motto is "More Good Times"
« Reply #11 on: January 05, 2016, 01:41:45 pm »
Do you say this because you don't have a tower already?  The transfer part is very easy - literally copy and paste.
spystyle
« Reply #12 on: January 05, 2016, 03:10:51 pm »
The "GBS-8100" looks like a good concept, but it got one bad review on amazon dot com :
http://www.amazon.com/Andoer-Portable-GBS-8100-Definition-Converter/dp/B00XKWX4F8/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1452024409&sr=1-1-catcorr&keywords=GBS-8100
Most laptops have VGA out, so a solution like that would work.
Or just switch to a computer monitor LOL.
monkeybomb
« Reply #13 on: January 06, 2016, 12:23:05 pm »
That review is accurate, and I still don't know of a good way to use a laptop with an arcade monitor, but I misread the first post.  I thought it was already an arcade cabinet, but he is creating a "new full-size mame cabinet."  Probably no need for 15khz.
oldschoolplaya
  • Last login:September 11, 2025, 03:20:04 pm
« Reply #14 on: March 04, 2016, 02:08:11 pm »
I've successfully configured a notebook PC inside my JAMMA MAME cabinet.  More challenges than a PC, but it can be done.
To output the VGA signal to the 15k arcade monitor, I used a GBS-8100 board to downscale the VGA output.  I still have a problem I can't figure out - randomly, the monitor will drop the red color and the monitor shows the game with the color missing.  Just as random, the color will come back after a few minutes.  I've determined it's the 8100 board and not the monitor or laptop that's doing this.  I've tried two 8100 boards and they both do the same thing, so I have no idea how to fix.
To turn the laptop on / off, I leave the laptop in standby mode and configured it to awake on the click of a mouse button.  The I wired up an old mouse with a switch soldered to one the of mouse buttons so a press of the switch will simulate a mouse click, which will wake up the laptop.  I then set the O/S on wake up to fire off my MAME frontend, Hyperspin.  To put the laptop to sleep, I configured Hyperspin on power off to put the laptop in suspend mode.
There ya go, no hacking your laptop's power button.  If only I could figure out the color problem on the GBS-8100.
P.H.U.
« Reply #15 on: March 04, 2016, 02:26:48 pm »
Really dependent upon the graphics card in the laptop. Couple of ways you can do this:
  • Soft 15khz
  • GroovyArcade off USB stick
  • External VGA-to-CGA convertor
- Soft 15khz doesn't work with all cards.
- GroovyArcade works with a limited number of graphics cards, but see if it works with yours. It runs off Live USB or CD and doesn't make any changes to your laptop configuration.
