Author Topic: How to map an analog controller (Xbox 360) to games that take 49-way joystick in  (Read 3572 times)
keylimesoda
  • Last login:November 18, 2015, 06:21:19 pm
I'm playing NFL Blitz and I'd like to emulate 49-way input using the analog stick on my Xbox 360 controller.  Is that possible, and if so, how would I configure it?
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
I actually don't see an option to map an analog stick in Blitz even with 49-way mode turned on.  Most of the other 49-way games just show up as Analog X and Analog Y. Not the case here.
IIRC there is a dip switch setting for 49-way or 8-way sticks.  I don't know if that would make a difference in what MAME allows you to map.
DarthMarino
Yeah, that's how I activated 49-way mode.  The games test menu states that 49-way is enabled but no new options appear in the MAME mapping. Whatever is mapped to the digital joystick doesn't respond in the game or test menu.  I didn't have time to fire up my other computer so I only tested the original game. I can try 99 and 2K tonight.
keylimesoda
2k has the same issue--triggering 49-way dip switch doesn't cause an analog option to present in the control UI.  Can't speak for 99.
So, does Mame usually provide the analog control UI for 49-way input games?  If so, how do we enable that configuration for the NFL Blitz games?
DarthMarino
That's something a developer would have to change.  I guess the best thing to do is to report it on MAME Testers.  I signed up 10 months ago and I'm still a "viewer". Otherwise I would report it myself.
keylimesoda
I'm not above patching some code on a local clone of MAME.
It looks like we're trying to modify the input ports for the Seattle.cpp driver.  I've reached out to Aaron Giles, who wrote that driver, but he's on sabbatical right now.
I'm guessing I could lift similar input port code from a working 49-way game like Sinistar.
